Question about Lexicon Audio Players & Recorders
Change fuse in lexicon cp3 - Lexicon Audio Players & Recorders
My lexicon mc 12 pre amp won't power on. The lead
There may be a secondary fuse inside the unit, if not the problem will be in the power transformer, if you are handy with a digital post back and I will give instructions on testing the transformer.
Jun 09, 2012 | Audio Players & Recorders
Lexicon MC12HD won't power up.
Could be an open internal fuse or power supply failure
Aug 31, 2017 | Televison & Video
I have an I-Onix u42s which worked great up until today when I turned it on and it's not picking up any input sounds. I tried every input and no sound is coming through. I changed nothing on the...
Probably the sound and devices settings in Windows control panel have been clobbered back to the computer audio instead of the Lexicon. Check the device defaults in "Audio" and "voice" tabs in the "sound and devices" in the Windows control panel.
Jun 01, 2011 | Lexicon I ONIX U42S 4x2 USB 2.0 DESKTOP...
Hi ihve soundcraft efx12 & the problem is in the effect, it hanges if i use the program selector, all the leds related to lexicon effects lit up.ithink the problem is in the the lexicon card. please...
If the LED's are level indicators, you are probably saturating the input of the effect and may cause it to hang. Effects use delay and feedback and can cause numerical overflow and the system to basically crash. I would first call the Lexicon support and ask them about this problem... I did have to return one Lexicon product myself for service under warranty.
Mar 25, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
Whats the polarity of lexicon ionix u22 audio adaptor? should i set plus or minus polarity on the adcd transformer/adaptor? thankx
Easy answer: You DON'T set the polarity because this particular device takes a 9 VAC at 2.1 amp adapter. (Not a DC one like so called universal ones)
It sounds like you have one of those universal adapters which probably would not deliver the 2.1 amps required even if the lexicon took DC. Note that stuff might light up, but the unit will not work using a DC adapter..
You had better get an official power supply for this unit as what you have will NOT work, period!
I did a quick search to try and find a link to a supplier, but they are RARE !!! Every one I found would require you changing the plug to match the Lexicon.
You should just order the correct one from Lexicon.
Feb 04, 2011 | Lexicon U22 Ionix U-22
Device is unrecognised always day per day
I've been struggling with this issue for about a week. My unit was locking up increasingly more often.
Two things I've noticed about my Lexicon interface:
1. Seems to be excessively hot.
2. The unit is not vented.
Yesterday, after reading a comment about the solder possibly being the problem, losing conductivity as the units warms up. I decided to run my Lexicon with the plastic case removed.
Since removing the the case, i have only had one instance where the sound stopped working, which i believe was a problem with Cubase in that instance.
I'm not sure if removing the case to keep the unit cooler is the solution. I may have improved a connection somewhere in the process of opening up the unit.
I can say that I went from getting a "new hardware found" message every two minutes to having virtually no problems since removing the case.
My next step will be to drill about 50 holes in the case to vent it before attempting to use the case again.
Best of luck to ya!!!
Nov 06, 2007 | Lexicon Omega Pro Studio External Sound...
55 people viewed this question
Top Lexicon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
