The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are: 1) Green On, Red Off = Printer Ready. 2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up. 3) Green Fast-Flashing, Red Off = Printer off-line. 4) Green Slow-Flashing, Red Off = Processing Data. 5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing. 6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset. 7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted. 8) Green Off, Red Off = Printer power is off. 9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode. 10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
