SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
SOURCE: I have a highlander 2005 and had a Avital remote
It sounds like the tech who installed this in your truck doesn't know what he is doing. I have been a tech for 20 years and have done 100's of these trucks for keyless remote starts. The door lock wires are in the drivers door or behind the glove box. There is some time in doing this because you have to build relays and use diodes for them to work, but it is possible to be done.I would find another place to do it and bill the first place that could not do it.
SOURCE: Had some work done on my 03 Eclipse and now my
im willing to bet your mechanic seen a wire he didnt think belonged there and just cut it (happens all the time with aftermarket electronics)
SOURCE: I bought a used car
The Camry you purchased may not be equipped with a power trunk. Press and hold the trunk button for appoximately 4 seconds. The trunk should release if the wire is connected and, you have a power trunk.
The Camry (and other toyotas) require a double pulse on the unlock wire. If the double pulse is not programmed the aftermarket unit will mimic the factory keyless entry. One press of the unlock button opens the drivers door. Immediately press the unlock button again to unlock the other doors.
I just went thru this, unplug everything from the brain on the remote starter, then plug it back in and reprogram the bypass and you should be good to go.
