Question about Health & Beauty
I have a mpv 5 hoveround and no power to right motor. Was flashing 4 lights now flashes 2...help!!!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Well that is a right motor fault,2 flashes is a battery fault needs charging make sure battery cables are connected properly
Posted on Jan 20, 2014
SOURCE:
  • 7 Answers
SOURCE: joystick on hoveround MPV 4 won't work. Are there
Check that the wiring leading to the jowstick hasn't knocked loose. It may have come out or just be out of place. You may have to get a new wire. Check the place you got it from for more details, go there in person or check the site.
Hope this helps!
Posted on Feb 22, 2009
SOURCE: I need an instruction manual for a Hoveround MPV 4 Power Wheelcha
Call 1-800-771-6565 extention 5000. You will need the serial number of the chair and then they will get you a manual.
Posted on Apr 08, 2009
SOURCE: hoveround mpv 4 goes in circles!
I had the same problem. There are circuit breakers under my seat, one of them had opened. (It was a push button type and was popped out further than the other.) Under the seat, near where the cables all connect. All I had to do was reset the breaker. I know what caused it. I was making a tight turn, and one tire was very low and over loaded the motor.
Posted on Apr 23, 2009
  • 4 Answers
SOURCE: Hoveround mpv4 does not work led flash when turned
This 8-light code is a joystick controller problem. It is an internal problem with the circuit board located inside the joystick. The entire joystick assembly would need to be replaced in this situation. If you are in need of a joystick, I have several for sale.
Posted on Aug 14, 2009
  • 175 Answers
SOURCE: MPV 4 lights flash on control and charger indicate...
I think this chair uses the VSI joystick controller, and those flash codes are located here: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Posted on May 23, 2010
My hoveround light flash and then goes off wont move.it is in forward gear and the batters are ok.thank Charles
The number of lights that are flashing will indicate what the problem is related to.
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. Try resetting your brakes to see if that will help reset the system (makre sure the power chair is turned off first.) If your insurance purchased the power chair for you, they may also cover the repairs; contact Hoveround for an appointment.
Dec 08, 2010 | NRS Hoveround MPV 5 - Used Power...
Tip
How to Diagnose Trouble Lights on Hoveround Power Wheel Chairs
Here is a link with descriptions of the flashing controller lights for most power wheel chair controllers. This will allow you a fast diagnosis to save time and money on your repair; it may be as simple as a brake reset instead of a costly motor replacement! The first page you will see is especially for Hoverounds, but you might be able to find other brands if you know the manufacturer of the controller.
on Oct 05, 2010 | NRS Hoveround MPV 5 - Used Power...
When mvp4 is turned on the battery lights come on and then go out and the speed indicator lights come on flash several times and then nothing.
Count the number of flashes this will give you an error code and you can determine the error by the number of flashes your users manual should list the error codes and their meaning. If not call Hoveround Tech support for help Hope this helps you
Oct 30, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Cant get my hoveround to start
Make sure the batteries are fully charged, the fuses are intact, there are no flashing lights on the controller and the brakes are in the upright "drive" position.
Oct 04, 2010 | NRS Hoveround MPV 5 - Used Power...
Where can I get owners manual for MPV 4 Hoveround?
I've looked at the Hoveround website and couldn't find a download for a manual for the MPV 4 So i would recommend calling Hoveround directly and asking for one You can call 1-800-542-7236 Hope this helps
Sep 30, 2010 | NRS Hoveround MPV 5 - Used Power...
Mpv 4 lights flash on control and charger indicates fully charged but cannot get it to go.
May 21, 2010 | NRS Hoveround MPV 5 - Used Power...
Have a Hooveround Teknique FWD wheelchair,
Five flashing lights indicate Right Motor Wiring Trip- The right motor has a short circuit to a battery. Check all the connections and leads between the right motor and the battery.
May 15, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Have a Hooveround Teknique FWD wheelchair, replaced circuit board in joystick, checked all wiring, but 5 lights rapidly flashing. Any ideas please
5 bars indicate a short circuit from the right motor to the battery. Check all the connections and leads between the right motor and the battery.
Mar 27, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
My mpv 5 turns on and horn works but wont move
Make sure both manual brake levers are in the UP/DRIVE position. They are located just above the footrest between where your ankles would be. If they are both up and there are no flashing lights on the controller, the motors may be bad.
Nov 26, 2009 | NRS Hoveround MPV 5 - Used Power...
Hoveround MPV 4. Joystick problem?
Count how many lights are flashing to determine the root cause of the problem. Here is alink that may help:
The abrupt stop may have knocked something loose.
Apr 09, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
Health & Beauty Logo
35 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
