Question about Necchi 3102 Mechanical Sewing Machine
Necchi 3205 FA: Seized
Machine is seized with the needle in the down position. Any ideas how to fix it?
    Champion:
  • 208 Answers
It may not have seized there may be a very small piece of thread jammed in the raceway area, you need to take the bobbin case and the raceway out to check
Posted on Sep 27, 2013
SOURCE:
  • 34 Answers
SOURCE: Needle not going up and down on necchi 544
There should be a button in the balance wheel on the left side of the machine. Not sure on your model, but most of the Necchi's pull out and push in. That disenguages the needle arm to wind a bobbin. Some of them screw in or out, but generally pull out. You might try pulling it out and then pushing it back in, until it clicks. Then it should work fine.
Posted on Jun 08, 2009
SOURCE: Model 3205 FA not picking up bobbin thread, needle
- check ifu are using same needle model.
- check hight of needle bar is ok
- check timming between needle bar and hook.
- check if your material is very stritch or no
- check blad point of hook is ok or no
best regards
Posted on Aug 20, 2009
RickE1
  • 202 Answers
SOURCE: I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Posted on Aug 29, 2009
dj_relly999
  • 4070 Answers
SOURCE: Necchi Model 535 FA
Hi! The motor pulley may be worn and cant turn properly causing the motor to be forced so much. The result will be an instant overheating that results to belt burn too. You will need to replace the motor, pulley and the belt now to make it running. Hope this helps and have a good one!
Posted on Jun 05, 2010
SOURCE: necchi sewing machine problem
needs to be serviced
Posted on Jul 31, 2010
M Necchi Pl1026 feels like it is froze up, the gears don't move
If it is an older mechanical machine, you are probably correct. It has probably seized due to lack of regular oiling and cleaning.
Wheel on right side that controls the needle up and down is very tight...
Jul 16, 2018 | Necchi Sewing Machines
Necchi 4575 feed dogs won’t work does not push material through
If you raise the presser foot, set the stitch length to a 3 or higher, then slowly press the foot control, can you see the feed dogs rise, move backward, then drop and come forward again? If they are not moving, the feed dogs have seized. If they are moving but do not rise above the needle plate, then you have them disengaged.
If they are seized, resist the temptation to run the machine anymore until you can get it serviced. It could damage the motor causing more repair cost.
If they are disengaged (dropped), then you need to find the control lever or dial that engages them.
Jun 23, 2018 | Necchi Sewing Machines
The needle displacement lever on my Bernina Favorit 740 will not stay in the center position. It sews in the right or left needle position but the zigzag won't go across the entire width.
I have a 730 (Record) but the mechanism is the same.
There is a spring loaded positioning 'finger' that pushes against a shaped 'rest' to keep it in place, and over time these seize up. Yours has probably seized while pushed in, meaning it doesn't hit the rest at all. I've attached a picture with a red arrow showing the finger.
You need to get it freed to get it to work again. Every 1960s Bernina I've seen has had the finger stuck in the central position, as well as having the positioning dial also seized, so it could be a lot worse :-)
Nov 13, 2017 | Bernina Sewing Machines
How to thread a Necchi 3205 FA royal series
Search for:
Make Model threading
or
Make Model manual
https://www.sewingpartsonline.com/instruction-manual-necchi-3205fa-sewing-machine.aspx
Even if not your particular model, basic machine threading is very similar from one to another. Just be sure to ALWAYS RAISE the presser foot when threading the top thread---and change the needle often.
How do thread Necchi Royal Series Model 3205 sewing discussion topic...
How to Thread Necchi Sewing Machine
How to thread Necchi model 535 FA sewing machine now with captions
Nov 06, 2017 | Sewing Machines
Where can I get a free downloadable manual for the Necchi 3101 FA?
Necchi Sewing Machine 3101 FA Manual - I Fix Machines
www.ifixmachines.com/.../1619-necchi-sewing-machine-3101-fa-manua...
PDF replacement manual, owners guide,instruction manual for your Necchi ... lost or damaged Necchi sewing machine model 3101 FA instruction manual.These manualsare downloadable and you'll need the free adobe reader to open them.
Nov 07, 2015 | Necchi Sewing Machines
Where cn i purchase a power cord and foot controller for a Necchi heavy duty model 3205 fa?
http://www.sewingpartsonline.com/foot-control-and-cord-universal-419451-003.aspx
Sep 29, 2015 | Necchi Sewing Machines
My machine is currently seized up with a baby quilt on it. The needle is down all the way and will not budge. When I depress the foot pedal or turn the wheel, it sounds like it's going to take off a
Undo tthe needle to raise the needle arm ...this will allow you to get under and carefully cut away the jam....there really is no easy way, and you may have already damaged the fabric if it is in the feed teeth, so be slow and gentle.
Jan 14, 2014 | Necchi 3102 Mechanical Sewing Machine
I have a Necchi 3205 Royal series machine. I was sewing denim and it jambed and bent the needle. I replaced the needle and now it won't pull the bobbin thread up. I have tried several different needles...
Hi, I've got a necchi sewing machine too, not the same model as yours.
you said you were sewing denim & the machine jamed & bent the needle, it's sounds like the machine is out of time, sometime it doesn't take much to get them out of time & would have to be serviced by a repair shop with the tools needed to fix the timing.
Aug 29, 2011 | Necchi Sewing Machines
Model 3205 FA not picking up bobbin thread, needle goes down but doesn't pick up bobbin thread, needle not bent, macine was working fine then all of a sudden bobbin thread stopped. Can't even pick it up to...
best regards
Aug 15, 2009 | Necchi Sewing Machines
Necchi 3102 Mechanical Sewing Machine Logo
192 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
