Question about Yardworks Tow Behind Broadcast Spreader
Setting greenview fertilizer
I have a Yardworks tow behind spreader. I am applying Scotts fertilizer. What are my settings?
I have a new Scotts Classic Drop spreader and an old bag of 16-4-8 fertilizer. 2,130 SF of Zoysia Zeon lawn. According to my guidance I need to spread 6.5 # of the 16-4-8 fertilizer over the entire area....
Does the product you are using list any Scotts AccuGreen spreader settings? If so, you can safely use the spreader settings listed for the Scotts AccuGreen. If your product does not list any spreader settings, please give Scotts a call at 866-465-5160.
Hilary @Scotts
Aug 27, 2011 | Scotts Company Scotts Turf Builder Classic...
I have lost my instructions for my hand held spreader. The numbers on the side that control the outlet of whatever is in the spreader--do these indicate the number of pounds per 100 sq. ft?
Below is a list of spreader settings. You may want to call Scotts at 800-543-8873 and verify the product you are using is able to be used in a hand held spreader.
  • For fine grass seed (blue, rye, fescue) use setting 1
  • For coarser seed (tall fescue) use setting 2
  • For light fertilizer (Scotts fertilizers at a regular rate) use setting 3
  • For heavy fertilizer (Scotts fertilizers at a heavy setting) use setting 4
  • For pelletized fertilizer and ice melt products use setting 5
Hilary @Scotts
May 16, 2011 | Scotts 71133 Handgreen II Hand Held...
What setting do I use for my scotts edgeguard DLX when using lesco professional starter fertilizer 18-24-12, item#016420
If the product you are planning to apply has a spreader setting for a Scotts SpeedyGreen, or specifially for the SpeedyGreen 3000; you can use that recommendation in your Scotts EdgeGuard DLX . If they do not have a suggested spreader setting for the SpeedyGreen or SpeedyGreen 3000, then this question would best be answered by calling Scotts directly at 1-800-543-8873. One of our associates would be happy to assist you further.
May 12, 2011 | Scotts Company Scotts Pro Edgeguard...
I buy Scotts fertilizer and use an earthway broadcast spreader.
add 10 - Scotts Turfbuilder spread at # 4 on a Scotts spreader should be on setting # 14 on an Earthway spreader.
Mar 28, 2010 | Earthway "Earthway" Medium Duty Commercial...
Settings for scotts products
The bag of fertilizer should tell you on the back of the setting for your spreader. It will say, Scotts 3000, Greenway XXX, etc, with the setting for that particular product.
Dec 29, 2009 | Earthway Ev - N - Spred Model 2050p Estate...
Need to apply lawn fertilizer at a rate of 5 lbs, per 1000 sqare feet, what setting do i need on my scott's speedygreen 3000 broadcast spreader.
http://www.gardentech.com/spreadersettings.asp
this is a link which will help you. Your setting should be on 7-8 using a criss-cross distribution pattern
Sep 07, 2009 | Scotts Company Scotts& Accugreeen 2000...
Yardworks Tow Behind Broadcast Spreader Logo
48 people viewed this question
Top Yardworks Garden Experts
roeb
john h
Marvin
Marvin
Are you a Yardworks Garden Expert? Answer questions, earn points and help others
