SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
SOURCE: Motor Wiring
Two white wires are for the electric brake. When the wheelchair is turned off while on an incline, the motors automatically lock up, preventing the wheelchair from rolling backwards. The white wires disengage the electric brake when power is applied.
SOURCE: Jet 7 will go backwards,
bunny You will need to count the number of flashes 5 flashes pause 5 flashies etc This is a flash code and you can tell by that what the problem is. If you have your users manual it should have a section on flash codes. Hope this helps you
SOURCE: I have changed out the
Donna sounds like the wiring could be the problem. Did you change the batteries? Does the joystick light up when you turn the chair on? Or does the breaker pop when you try to turn the chair on? Give me as much info as you can as to what you are doing when the breaker pops thanks
I urgently need a solution as I use my chair for everything as I am completely immobile.
