SOURCE: the rear of my car is low, seems like the air susp. doesn't work
Have it tested for a leak. Do not run the compressor if you do not have to. You will burn out the compressor. Sysytem will have to be pumped with air to pin-point leak
SOURCE: 1998 Lincoln continental Riding high in the rear.
have the code read and it will aim you in the right direction for repairs
Why have you not unplugged the compressor or
removed the fuse?
That whole problem you have is so simple
The most trouble you could possible have is to
get the check light off & a look at a wiring diagram
would resolve that
