New Ray 1/32 Peterbilt 379 Grain Hauler #12083 Logo
A
Anonymous Posted on Sep 25, 2013
Peterbilt 379 119 heater won't turn off - New Ray 1/32 Peterbilt 379 Grain Hauler #12083
I have a 2016 Peterbilt 567.A/c works great. heater will not warm the cab. it just blows cold qambient air even if the engine is at 200 degrees
you can get help from the service and repair manual which will guide you to fix the problem with diagram and you cna get the manual from the given link http://toolsnyou.com/
How do i find where the short is in my 379 peterbilt between door lock and dash lites?
Hi you have a short or break in the wiring its usually were the hinge movement operates that the wiring loom goes through.
1helpful
2010 peterbilt 387. Why doesn't heat come out?
check that the heater control tap is being turned on when you select hot
check for air trapped in the heater core and not allowing hot water to circulate
2015 Peterbilt 387. Why doesn't the heater work?
It's so new you should not have a problem but you are not getting coolant to flow through your heater core. I suspect an electrical problem around the water shutoff valve or a vacuum hose or cable not opening the heater valve. You might be able to manually open the heater valve.
1994 Peterbilt I need a complete Heater Hose Diagram
has to be some diagrams on internet somewhere. Did you try Peterbilts web site?
WHERE ARE THE FUSES FOR THE RIGHT TURN SIGNAL ON A 2010 PETERBILT
A tractor is not software, please repost in the correct catagory.
5helpful
3answers
Top New Ray Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a New Ray Toy Expert? Answer questions, earn points and help others
