Question about Motorola Mobility H560 Bluetooth Headset
Red blinking light
Light is flashing red but I am using an LG cell phone charger that seemed to fit do you think that is the problem?
  • 126 Answers
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Posted on Sep 25, 2013
SOURCE:
Iam using Energizer 15min charger. I have used for a longer time. Now the charger red light blinks while trying to re-charge batteries. I have tried various batteries but red light blinks. Failed to charge...
A flashing light indicates that the charger seems to detect a problem with the cells. (two or more cells form a battery). Since you've tried other cells, it can be reasonably assumed that the charger is faulty and should be replaced.
Feb 14, 2011 | Energizer 15 Minute Battery Charger Combo...
Ok here's what happened: My battery was almost dead, and I had recently bought a new charger, so I plugged it in before I went to bed and it was fine. When I woke up, the screen was blinking and the logo...
i think the problem is in the charger you bought... maybe it wasnt very compatible with the phone or maybe it has some deffects... try using a different charger
Jan 25, 2011 | LG KC910 Renoir Cell Phone
Turns off for no reason.
It is a common problem with them.Every couple days,remove the battery for a few min.and let the phone reset itself.You also should shut the phone off a couple nites a week.And remember not to over charge it.It is never a good idea to leave them on the charger for more than a few hours at a time.I was having the same problem with mine,And now it seems to be fine
thanks
Jul 05, 2010 | LG RUMOR Cellular Phone
No power will not charge sccreen flashes white
hello there,
the problem would be that the charger is not sitting properly, therefore it tries to connect but ends up not charging.
try to replace the charhing port of the phone then you can try to charge again. or look for a charger that fits properly.
goodluck
Feb 03, 2010 | Sony Ericsson Walkman W810i Cellular Phone
LG Secret (KF750) won't turn on
hmmmm mine also is doing tht....when i press the turn on button the red light at the back will come on then the phone turns on but it willl say LG and turn off i only got the phone today it was second hand.....dnt knw if it does tht if the battery is dead or what
Apr 26, 2009 | LG Secret ? KF750 Cellular Phone
My phone will not show it charging and will not turn on, red light flashing
i cant charge my phone using a charger
when i put the head phones in the same port, my phone does not pick up the signal
BUT when i connect my phone to the pc using a usb cable, it charges fine and i can transfer data
WHAT IS WRONG WITH MY PHONE????
Apr 19, 2008 | Cell Phones
Charging lg kg 220 phone
Almost certainly liquid damage to the lower part of the phone!
Depending on your skills, removing the back cover (the bottom lifts after removing the four screws and then you need to twist and tug the top to get the back off) and clean the bottom 1/4 of the phone using a toothbrush soaked in isopropyl alcohol. Then dry completely with hot air, a hair dryer will suffice.
10 out 10 non-charging KG-220 seem here in the last six months were all fixed using this method!
The classic indication is when plugging the charger into the switch on phone, the handset turns off.
Dec 11, 2007 | LG KG220 Cellular Phone
Mine started acting wierd and it was flashing on and off. someone told me to press:*and # together with the power button.
Oct 19, 2007 | Cell Phones
I think I just ruined my cell phone.
ic im glad you fixed your own problem
Oct 10, 2007 | LG VX6100 Cellular Phone
Motorola Mobility H560 Bluetooth Headset Logo
1,844 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
