The yellow lamp is flashing and printer dosn't work .My printer is pixma mp510 canon
How many times does it blink... 2, 3, 12....
2 times Carriage error [5100] An error occurred in the carriage encoder signal. - Carriage unit (QM2-3753)
- Timing **** film (QC1-9542)
- Logic board (QM2-3827)
- Carriage motor (QM2-3872)
3 times Line feed error [6000] An error occurred in the LF encoder signal. - Timing sensor unit (QM2-3878)
- Timing **** disk film (QC1-9597)
- Feed roller (QL2-1407)
- Paper feed motor (QM2-3873)
4 times Purge cam
sensor error
[5C00] An error occurred in the purge unit. - Purge unit (QM2-3754)
5 times ASF (cam)
sensor error
[5700] This error takes place when feeding paper from the
ASF after an error occurred in the ASF cam sensor.
- Sheet feed unit (QM2-3762)
- ASF_PE sensor board (QM2-3877)
6 times Internal
temperature
error
[5400] The internal temperature is not proper. - Logic board (QM2-3827)
7 times Ink absorber
full
[5B00,
5B10,
5B01,
5B11]
The ink absorber is full.
Error codes:
Overseas:
5B00: Main ink absorber
5B10: Borderless-print ink absorber
Japan:
5B01: Main ink absorber
- Ink absorber kit (QY5-0178)
1-5
Note: Before replacement of the logic board ***'y, check the ink absorber counter value (by service test print or EEPROM information
print). If the counter value is 7% or more, also replace the ink absorber kit (QY5-0178) when replacing the logic board ***'y, or
register the current ink absorber counter value to the replaced new logic board instead. [See 3-3. Adjustment / Settings, (9)
Service mode, for details.]
2-3. Other Error Messages
5B11: Borderless-print ink absorber
8 times Print head
temperature
rise error
[5200] The print head temperature exceeded the specified
value.
- Print head (QY6-0070)
9 times EEPROM
error
[6800] A problem occurred in writing to the EEPROM. - Logic board (QM2-3827)
10 times VH monitor
error
[B200] The internal temperature exceeded the specified
value.
12 times PG position
error
[5C10] An error occurred in the PG motor during purging
operation.
15 times USB Host
VBUS
overcurrent
[9000] The USB Host VBUS is overloaded. - Logic board (QM2-3827)
19 times Ink tank
position sensor
error
[6502] None of the ink tank position is detected. - Spur base unit (QM2-3750)
20 times Other
hardware error
[6500] The PCI bus error is detected by the ASIC. - Logic board (QM2-3827)
22 times Scanner home
position error
[5010] The scanner unit cannot detect the home position, or
the scanner unit warming-up is not performed
properly at power-on.
On the LCD, "Scanner is not operating correctly." is
displayed.
- Scanner unit (QM2-3775)
Alarm and Power
LEDs lit
ROM error,
RAM error
A flash ROM or RAM checksum error occurred at
hard-power-on.
