SOURCE: towels smell burnt after washing.
Are you sure the burnt smell is coming from the washer and not from the dryer? If you've placed a rubber backed rug or other similar article of clothing, it is not uncommon for that rubber backing to melt and get embedded in the heated duct of the dryer . Not sure this helps but if you can clarify the point at which the burnt smell is first observed that would help..
Thanks
SOURCE: Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
SOURCE: mold on the rubber seal of bosch washing machine
RUN A LOAD OF HOT WATER WITH 1 QUART OF WHITE VINEGAR, THAT WILL KILL THE MOLD, THEN WIP IT OFF THE SEAL
SOURCE: LG washer, rubber burning smell
Did you get this seal problem resolved, by yourself or did you call in a repair-person? If you did it yourself, was it difficult? Same problem found 12/17/10 - Thank you
SOURCE: grease stains on clothes from LG washer (tromm 2688)
We run a small hotel and have been having this same problem with our LG Direct Drive WM2301HW... but the stains aren't grease at all... they're from sledge buildup in the washer. I found this out when I cleaned the lint trap behind the small door at the bottom left, on front of the machine. I ran my finger around the interior and found it lined with black, stinky muck. Due to the low position of the filter, this area never fully drains, so the muck collects and the bacteria grows. Of course, this means the pipes or hoses to the filter are probably also lined with this muck.... Poor design!!! Try running the washer empty (no clothes) with a couple cups of honest to goodness chlorine bleach. Then run it again to make sure all the stuff that came loose gets pumped out.
