Thanks very much - most helpful. Whilst writing, do you know what the temperature should be on a freezer? SandyThanks very much - most helpful. Whilst writing, do you know what the temperature should be on a freezer? Sandy
should be fast freeze, switch the f/f button off and see if the light goes out !!should be fast freeze, switch the f/f button off and see if the light goes out !!
Could you please recheck for the model number. R134A is a reference to the coolant used in the freezer mechanism.
Orange is often a reference to the 'Fast Freeze' function being turned On. Green is showing the freezer unit is at the correct temperature. Red is warning the freezer is Too warm. Some freezers are fitted with an 'Economy' function where the freezer can be run at a lower power level when not used regularly such as when on holiday.
That yellow light on sonne older modelks is just showingbtge power is on. I never heard of a chest freezer having a "quick freeze" feature. This feature would also require forced air cooling and auto defrost. If the walls get frost on ghr m t hen Im betting that is ju st a power light although it may say freeze or something else like that. Its just so when you see the yrllow light you know there is power.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Draw fan has failed, temp unreachable over the past cycle of 24hrs, turn your unit off for 24hrs and defrost it, restart and should work fine for a few days, if so, replace fan and defrost element only. Call service tech for this unless you are clued in on this work, not that costly.
THE RED WARNING LIGHT KEEPS COMING ON AND I HAVE TO KEEP PRESSING THE FAST FREEZE BUTTON, THIS IS EVERY FEW DAYS. IF I DONT NOTICE ALL THE FOOD DEFROSTS!
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Brilliant - thanks very much. You sure know your stuff!
