Question about Polycom HDX 5-Shelf 18 in. D x 36 in. W x 72 in. H Plastic Ventilated Storage
Need 4 poles that support shelves - Polycom HDX 5-Shelf 18 in. D x 36 in. W x 72 in. H Plastic Ventilated Storage
    Problem Solver:
  • 15 Answers
You can find all the parts for this unit at www.apgparts.com.
Posted on Oct 07, 2014
SOURCE:
Has a 5 pole socket for trailer wiring
Your terms are inconsistent.
Female 5 pole receptacle on the bike is what you need? You have a 4 pole male plug on the trailer?
You are looking for some sort of adaptor? Please show a picture of both ends, it would help.
May 13, 2014 | 1994 Honda GL 1500 SE Gold Wing
I need parts for and hdx shelving unit model 1701099
You can find all parts for this unit at www.apgparts.com.
Dec 09, 2013 | Polycom HDX 5-Shelf 18 in. D x 36 in. W x...
I need the written instructions to set up an avid screen gazebo 13x9 model 2086 that I just bought at a yard sale. PLEASE HELP.
How To Assemble Avid Outdoors Model 2086 Screen Gazebo
Start with # 4 poles. There are 4. Attach a #3A to each, and then attach #3 to the other end of the 3A.
These are the 4 legs.
There are 6 #2 and 3 #2A. Attach a #2 to 2A, and then #2 to the other end of the 2A. These 3 are the top ridge pole and the 2 side poles.
I believe there are 4 #1 and 4#1B. Attach a 1 and 1B together. Do this 3 more times. These are the gable poles.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down.
Jun 26, 2013 | Garden
Avid outdoor screen gazebo instructions for set up #2086
Start with # 4 poles. There are 4. Attach a #A to each, and then attach #3 to the other end of the 3A. These are the 4 legs.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down. How's that?
Sep 17, 2011 | Garden
I lost instructions for my Avid Outdoors screen gazebo model #2086 13'x9'. Any help is appreciated
avid outdoor doesn't offer instructions...can someone please post instructions for some of these...it would really be helpful...its crazy that some of these boxes dont come with instructions?!
Jul 18, 2011 | Garden
I am replacting my T104 timer with a GE 15601. The posts on the T104 are marked 1 2 3 4. However on the 15601 they are marked L 1 X 2. How do these map to each other?
GE 15601 is a replacement module for Intermatic timers.
Intermatic timers can snap inside the old box without needing to replace the box, and GE has made a product that taps into that market.
But the GE manual is missing key facts like clock voltage and wiring.
The following information is correct ONLY if the GE timer is rated for 240Volts Why? The T-104 is a 240V timer. I have 10 different Intermatic timers on my office shelves right now, and wrote the T-104 page linked to above.
Below is picture of the back of GE timer taken from GE manual.
Please look at the image as a reverse image of your wiring poles.
T104 has poles A 1 2 3 4
Black wire on Intermatic Pole 1 is the Hot from Breaker
Black wire on Intermatic Pole 2 is the Black to Load
White wires on Intermatic Poles 3 and 4 are the White from breaker and White to Load. So on the GE timer, 2 white wires are on same pole.
On the GE timer, there is a brass connector between 2 of the Poles that connects those poles electrically, so no wire goes on one of the GE Poles
That's the wiring changeover.
Up-vote if the information helped you.
Oct 13, 2010 | Intermatic T104 24h 208-277v Mechanical...
Im r\putting in a new timer, i have 120 going in to the line, terminal 2 , and 2 load circuits hooked up to termials 4 and 6, neutral on terminal 1. When i power it up i have 120 volts on terminals 1 and...
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et8215c%20-%20english.ashx
I am looking at the wiring diagram
The timer is shipped pre-set for 120V
DST enabled
Loads to be independently controlled
Move jumper to SIM for simultaneous operation
STATIC discharge can damage circuit board
neutral on pole 1
hot on pole 2
Now your 120V circuit powers the timer, but it does NOT send power to the other poles
If I understand your explanation correctly ... you have load wires on poles 4 and 6 but no Hot wire connected to poles 3 and 5?
I think you need to run a Hot wire to poles 3 and 5.
To double check this, run a continuity test between Hot pole 2 and poles 3 and 5 ... there is no voltage there ... the switch circuits operate separately from the timer circuit.
Another test ... when you hear the switch click ... test continuity between poles 3 and 4 and then test poles 4 and 5 >>> when the timer is on, those poles have continuity ... so connect Hots to 3 and 5 and the 2 Loads will work.
Oct 04, 2010 | Intermatic ET8215C- 7-Day Electronic...
How do i wire my diehl 880 ?
1) Here is Diehl 880 instruction manual
2) Diehl 880 is 120V timer
-1/2 HP
-1000 Watt tungsten. Tungsten means incandescent light bulbs.
3) Checklist:
a) Your load does not exceed capacity > Timer is too lightweight to control 1500 toaster oven.
b) You need 120V line coming from breaker box with black Hot wire and white Neutral
c) You need 120V line going to Load that also has black and white wire
d) Test each black wire to ground to see which black wire is HOT
4) Deihl 880 sell sheet pdf says 880 is available SPST (single pole single throw) -or- SPDT (single pole double throw).
-The difference is pole #4 on the timer.
-If you are trying to turn one circuit off just as another circuit turns on, then you need the SPDT
-If you are turning one circuit on-and off, then the following instructions are for you
5) Wire clock
-There are 5 poles > look for markings 1-thru-5
-If no marking, then poles 1&2 are probably spaced apart from other poles
-Connect Hot and Neutral wires to poles 1&2 >> this powers clock motor, they go on either pole
-Pole 4 not used
6) Wire timer
-Poles 3&5 are timer circuits
-Connect Hot line to pole 3
-Connect black wire going to Load to pole 5
-Connect white wire from Load to Neutral
Oct 01, 2010 | Diehl TIME CLOCK- 120V 24 HOUR
I need to program the timer
http://waterheatertimer.org/Paragon-EC4000-program.pdf
4 Buttons RUN MODE Arrow ENTER
Programming steps are long but straightforward
16 set points
Selectable clock format - 12 hour/ 24 hour
Day skipper
Manual has troubleshoot section, so expect the usual trouble
Wiring diagram at bottom shows 5 poles for 120V timer.
Hot and Neutral connect to poles 1 and 2
Jumper from Hot to pole 3
NC normally closed pole 5
NO normally open pole 4
Black from load connects to pole 4 or 5
White from load connects to Neutral at pole 1 or 2
Sep 28, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
The fridge back wall inside above the top 2 shelves are freezing over also the black cover on back of fridge one bit of pole going into the motor seems warm [is this normal ]
Your defrost system has failed. Defrost timer. defrost heater. Defrost thermostat. Without a model number I can not be further help.
Jun 07, 2009 | Refrigerators
Polycom HDX 5-Shelf 18 in. D x 36 in. W x 72 in. H Plastic Ventilated Storage Logo
1,014 people viewed this question
Top Polycom Furniture Experts
Tom Chichester
Marvin
Marvin
Are you a Polycom Furniture Expert? Answer questions, earn points and help others
