Connect the AUDIO OUT ports on your DVD player to the audio in ports on your TV with the regular or standard audio cables (red and white jacks). Connect the AUDIO OUT ports on your TV to your speakers using a standard audio cable, or a digital audio Optical cable.
Based on the specs from CNET, the Seiki SE322FS does not have an optical digital audio port. There is a coaxial digital audio port which looks like a standard RCA jack. The main difference is that it will be a single output jack, instead of the groups of RCA input jacks (component and composite audio/video ports). See https://www.cnet.com/products/seiki-se322fs/specs/ . See https://www.lifewire.com/coaxial-vs-optical-digital-cable-3134605 for some of the pros and cons for each type of digital audio cable.
Since the TV will be your audio source, you'll need a coaxial to optical digital audio converter. This is one example: https://www.cablestogo.com/product/40018/coaxial-to-toslink-optical-digital-audio-converter-taa-compliant . Note: usually the cables are not included with the converter. Thus, you'll need to get a coaxial digital audio cable separately. A different converter is needed to go from an optical digital audio output to a coaxial digital audio input.
The LG NB5530A only has a digital optical audio input. The LCD40883F1080P has a digital (S/PDIF) optical audio output above the RCA audio output jacks on the back connection panel.
Your best audio option is to use this connection. When new, the NB5530A came with a digital audio cable. Remove the protective plastic covers from the cable ends. Plug in the cable using the correct orientation on both sides. If the original optical audio cable is missing or damaged, purchase a replacement and use it. (The audio and power ports on the NB5530A can be covered by a plastic cover. Remove it if necessary and replace it.
If you want to use the analog audio output on the TV, you will need a optical digital to analog audio converter. You still have to provide the digital audio cable between the TV and the converter as well as the RCA cables. See https://www.amazon.com/Digital-Optical-Analog-audio-converter/dp/B004C4WPXA for one example.
Does your TV have a Digital optical port? It's a cable that sends a red light source. That is actually how you're suppose to hook up a soundbar. digital optical cable Bing images Straight forward. Plug and play. If you're TV doesn't have an optical port, as I know your soundbar does then you have to use a stereo Y Cable. 3.5mm to Red/White. Sound bar will have 33% the power going this way as opposed to an optical cable. Aux Audio Out has a itty bitty amp pushing power. Purpose of the Digital optical Cable is a light source.
This television only outputs digital audio called PCM / Dolby Digital, Fiber Optic so you may need an amplifier that has a digital in port (if the speakers are rca red and white cable plugs then the amplifier needs rca output ports). Then you would need to connect the amplifier to the speakers
. Unless the speakers have a digital in port which I am unsure on ,. The digital out audio port on your tv uses a fibre optic digital audio cable..
page 13 of the user manual shows this digital output port.
http://service.us.panasonic.com/OPERMANPDF/TCL42E50.PDF
Yes this can be done. You have several options for audio hookup. Stereo 2-channel (white and red) RCA cables, digital audio (optical or coaxial) or HDMI. Your home theater must have the inputs available such as optical, coaxial etc. Typically the stereo 2-channel RCA is the simple way. Just connect from the Bluray audio outputs to the Home theater inputs (white and red) for stereo sound. Select the input on the home theater. For Dolby Digital 5.1 use optical digital audio cable (black port) or coaxial (orange RCA port) from Bluray to similar home theater input.
Yes the digital audio cable should be inserted until there is a firm, clicking connection. It should only be able to fit in correctly with one orientation. It should be slightly difficult to remove when properly connected.
If your cable is slipping out, then I suggest you have a defective cable or (hopefully not) a damaged/defective optical connection port.
mini-audio cable. shielded cable same type as headphone.
the plug should have 3 break with plasic insert in between.(stero) or single break (mon). it may or may not have color code on them.
