Question about HP Media Center m7250n (ED842AA) PC Desktop
Volume control will not let me click on anything to fix the audio problems
    New Friend:
  • 156 Answers
Could be a Driver Problem..... did you use windows update before this issue? might need to go into the device manager (right click mycomputer and then click properties) and roll the drivers back... its aworth a try
Posted on Oct 15, 2013
6ya staff
SOURCE:
I HAVE A PROBLEM WITH TOSHIBA HARMAN/KARDON SOUND. I HAVE INSTALL SOUND DRIVERS AFTER THE OTHER BUT THERE IS NO SOUND STILL. PLEASE HELP ME WHAT DO I DO NEXT
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
Oct 31, 2011 | Harman Kardon HK695 Computer Speakers
Sound card working properly but no can be heard
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
also
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 16, 2011 | Dell Computers & Internet
What's your problem? my computer not read sound .i can not hear sound .what can i do ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers:
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume:
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check:
Sep 27, 2011 | HP (153147-001) Sound Card
Installed win-xp and the realteck 97 audiodrivers are installed but the sound was not audible what can i do for making sound?
A LIST OF SOUND ISSUES AND FIXES
also
Sep 23, 2011 | Computers & Internet
No sound
there can be many issues that cause sound problems with a computer
also
Sep 23, 2011 | Intel Motherboard
My Dell twin speakers suddenly not working today Monday 5.9.11. Were working OK about 3 to 4 days ago. Have not disconnected anything and all plugs seem to be in order. First time this has happened in...
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 05, 2011 | Dell A215 Computer Speakers
I cannot hear anything out of my speakers.
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 20, 2011 | Altec Lansing Multimedia Computer Speakers
I bought a soncm headphones sm-750mv no manual and the volume is low but i got my computer volume 100%.is thre anything i can do/
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar once the icon is in the tasbar you can adjust voleme setting by right click on icon
hope this helps
Jul 06, 2011 | Audio Players & Recorders
I cannot hear ANYTHING. The speakers are plugged in and properly inserted into the computer but i still cannot hear anything
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 11, 2011 | Kinyo PS-107 Computer Speakers
Sound plays but very low volume even if plug to speakers and amplifier and full volume, you hardly hear anything. Hoping for a solution. Regards,
right click on the speaker icon in the system tray on the bottom right side of the screen and then click to open the volume mixer then make the speaker sound level to 100 %.
or go to the control panel from there click on the sound or speaker icon to open it after that go to properties and then make the volume level to 100%.
This should help to fix the problem.
Mar 23, 2010 | Computers & Internet
Open Questions:
See all HP Media Center m7250n (ED842AA) PC Desktop Questions
HP Media Center m7250n (ED842AA) PC Desktop Logo
49 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
