Type this in google and you can watch the door panel removal on You Tube CA (MB AUTOHAUS MERCEDE BENZ FRONT DOOR PANEL REMOVAL FOR ML , GL, AND R CLASS )
Open crank window. Remove cover for door handle and unscrew 2 screws. Unclip SRS panel and unscrew screw. Press door liner off bottom, fron and rear inner door panel with wedge. Lift door liner up and out. Unhook inner door actuator. Unclip inner lock on door liner. Remove lamp.
pull off rear mirror panel, pull off electric seat adjuster knobs, pull off plastic around door handles. Unbolt top of handle. Pull out light at bottom of door. Unscrew plastic stiker plate and remove. Unscrew lock knob to remove. Then your ready to wiggle and pull the panel up and off, be careful of the area around the door handle, you may even want to pry that area out before you begin.
If you can lower the window down you can jimmy it open from there preferably from the inside has more padding in the inside seal compared to the outside one i can see the switches working but some how it detached itself try and hook around the area were the door latch is not door hinges lol it wont be an easy task but a thin coat hanger as well as possibly a rubber door stopper to give ya some space to work with may help out good luck take her easy with the door stopper don't push it in too far may crack the plastic
