HEWLETT-PACKARD Hewlett Packard P1102 Laser Printer Logo
blessing Posted on Sep 24, 2013
How to print wirelessly from android phone on hp laserjet p1102w
LADIDO
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 18, 2013
LADIDO
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
10401
Points
6
It dependes if you have local wifi where your HP printer is connected.
If yes, you only need to install HP ePrint app.
After you start the app ignore activate printing via hp cloud, you don't neet it. If you are with your Android on the same WiFi your app will identify the printer on the network and you only need to indicate the photo or file. Open it and print. Tha'ts all.
Hp laserjet wireless not found on my phone
why not RTM? (omg)
read the manual,
all this is covered there. how to CONNECT.
there is no phone support, apple or android. only xp to w10.
on newer printer, far newer, the phone can be linked to HP smart print servers and to your home system printers.
https://support.hp.com/us-en/product/hp-laserjet-pro-cp1025-color-printer-series/4052955/model/4052971/manuals
here is HP site page showing how to do that,
http://www8.hp.com/us/en/ads/mobility/overview.html
first pick a printer that does that.
using the smart app
or ePrint.
there are many ways to set that up, but direct cell to printer.
no. (yes new products can do direct cell print)
that is called wireless direct print , features, as see here.
http://www8.hp.com/us/en/ads/mobility/wireless-direct-printing.html
you said you have phone (cell apple or android?_)
then said have a laptop.
my cell , is android and I use local wifi , to save 3g charges
do you?
my laptop has internet connections 2 ways, wired, and wireless
does yours have wireless. seems not.? but.... do you?
you said no router, but if you go to any ISP today
and he installs internet service, there are 2 hidden router now
inside the old name modem,
the modern cheaper modem has that, hidden is side.
has 3 things in the black box.
so what do you have there that we cant see, devices to the ISP
with names and model numbers.
knowing that tells the helper what is possible , (all things)
my guess is you want to print, using the CELL.
if you dont have eprint mail the docs or photos to the laptop
then, print from Laptop
to printer using a USB cable, (USB is 10x more easy to make work)
your printer can connect up 3 ways.
Printer USB to PC. direct wired printing. ( always a choice, direct)
Ethernet to router. wired. (all things connected to this router can print.
wireless to router. printer to router joined, and print from any thing at home connected to said router.
if it must be wireless, (you must have that?)
then buy a router. and use that, and is safer behind any router firewall vastly saver too boot.
tip
How to print a configuration page from an HP LaserJet P1102w
The HP LaserJet Professional P1102w is a compact wireless desktop printer. It is very easy to set up and use. Unlike larger HP printers, the P1102w does not even have a true operation panel; it only has a power button, a cancel button, and a wireless button.
However, like just about every other HP printer, the P1102w has the ability to print out a configuration page that displays many of the printer's settings and statistics. This page is called the self test / device configuration page, and on it you can find the printer's page count, number of paper jams (broken down by section), amount of available memory, network settings, and more.
To print the device configuration page, make sure the printer is on and ready. The green light on the top left side of the printer should be lit. If the red light is lit or flashing, then there is a problem with the printer -- such as no toner or a paper jam -- and you won't be able to print the configuration page until the problem is rectified. You'll also need to have at least one sheet of paper loaded into the paper tray. Make sure the two side fences and the rear fence are snug against the paper to prevent misfeeding.
Press and hold the cancel button (the button with the red X on it) for about four seconds. The printer will warm up and begin making noise, and the green light will start to flash -- when these two things happen, you can release the cancel button. The printer will print out the configuration page, face down, and once it has finished the green light will stop flashing and the printer will quiet down.
Why does the printer beep when printing
to alert the user that their may be sensitive docs printing
Printer won't print
If your iPad can see other computers on the network but not the printer, try setting one of the other computers to share the printer and have the iPad access the printer as a shared device off of that other computer. We used to have to do this with for laptop on our home wireless network; we set one of our desktops up to share the printer so the laptop could find it.
Prints clean sheet - not printing anything on the paper
mine did that too, no text on page, we had to change the defeat setting from the router.
2helpful
My i phone 4 does not recognize my wireless hp printer 4500
Currently to use iPhone to use printing you need a airprint enabled printers! below is a list of them!
HP Deskjet 3050A e-AiO HP Envy e-AiO (D410) HP Photosmart Plus e-AiO (B210) HP Photosmart Premium e-AiO (C310) HP Photosmart Premium Fax e-AiO (C410) HP Photosmart e-AiO (D110) HP Photosmart Wireless e-AiO (B110)-Europe and Asia-Pacific HP Photosmart eStation (C510) HP LaserJet P1102w HP LaserJet P1606dn
there are more to this list and for information check http://support.apple.com/kb/HT4356
3answers
Won't Print
Usb or Parallel cable? if USB the computer should say new hardware found. If Parallel the should be checked to see if enabled.
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Obehiaghe Adoghe
Obehiaghe Adoghe
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
