SOURCE: Xerox Phaser 7400DX - leaves "smudges on the printed sheet
It sounds like you have a developer housing failure.
SOURCE: Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
SOURCE: Phaser 7300n Printing on Double Sided Glossy Paper
At first I didn't think the paper was the problem, but I looked up the specs on it and is seems to be a paper designed for an offset press.
I suspect after reading the information on the paper that the coating is not designed for the high temperatures of a laser printiers fuser heat of over 350 degrees.
I do suspect the paper is the issue.
sounds like you are melting the coating.
SOURCE: How to refill xerox phaser 6125?
Just found a supplier for toner and reset chips for my new 6125. Don't know where you're based but in the UK you can use the following link:-
http://www.zinetic.co.uk/Xerox_Phaser_6125_Toner_Refill_Rainbow_Pack-details.aspx
In the US, a possible source from EBAY is:-
http://cgi.ebay.co.uk/4-Xerox-Phaser-6125-6125N-6130-6130N-Toner-Refill-HY_W0QQitemZ380126889100QQcmdZViewItemQQptZBI_Toner?hash=item588154048c&_trksid=p3286.c0.m14&_trkparms=72:1683|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
Good luck.
MJN
SOURCE: how to reset chip on toner cartridge for Xerox Phaser 6125?
You can build your own resetter device, very simple and cheap,no need electronic knowledge here is the link:
http://www.tradebit.com/filedetail.php/178510406-at88sc0204-reset-software-full-package
Additional remarks about the problem: The Xerox 6125 test color print (with the horses) looks perfect, but when I strike my fingers over it, just the black color smears. The big letters 6125 and black parts of the picture bocome grainy and the white paper around it gets gray. The other colors have no problem.
Add a CommentIn the meantime, I bought the 6125 service manual, but did not recognize this problem and solution yet.
The fuser is supposed to be 347 degrees F. I suppose it never reaches that temperature. The surroundigs get barely warmer than my hand.
