I wanna run my lappy in safe mode..when i press F8 a beep is tonned and windows starts normally. what i do?
SOURCE: how restore the system by pressing F8 and go through dos prompt
TURN OFF THE PC & THEN RESTART IT AS SOON AS U RESTART PRESS F8 FOR 4-5 TIMES & WAIT FOR THE SCREEN TO POP UP & THEN U WILL SEE AN OPTIION AS LAST KNOWN GOOD CONFIGURATION (LKGC)
SELECT & HOT ENTER
SHOULD RESOLVE.
SOURCE: Laptop in continual stop start cycle
please the memory RAM with the same type and specifications.
SOURCE: windows vista cannot start in normal mode. it
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If
you are not able to enter in safe mode Then you need to fix error on
hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then
check if again you are not able to enter in windows then boot again and
this time choose "R" option for repair previous windows " then it
repairs old windows then it loads again old windows.
Thanks for using FixYa.
SOURCE: lenovo y510 wont start in normal mode (xp)
For the Lenovo to to start in the safe and networking mode, and then not have a display when you attempt to boot it in normal mode, I would follo the these steps:
Boot in networking mode, and then go to the Lenovo site and download the most current display drivers. Since you are able to operate as described above, I would start here first. Once you have successfully downloaded the most current drivers for the video on your system, BEFORE you leave the Lenovo site, check your system against the listed bios upgrades. I believe you may find you need to upgrade your system firmware. If so....download the upgrades you need, and finish the display drivers updates as discussed above, and keep the fresh firmware updates set aside and see if the display driver updates allow you to boot normally.
If so, once you have a normal boot, backup your systems RIGHT away! The next step is to then carefully read the docs about how to update the firmware. Sometimes this will require a floppy drive, if so, you can most likely either pick up a USB one very cheaply or perhaps borrow one. At any rate, make sure your system is backed up fully, and preferable with a restore point, (if you are able with XP?)
Try these measures, if it is successful I would love to hear that from you by way of a testimonial. If you are not - please return here for further assistance. I have additional help for you - but I do not think at this time you have a hardware problem.
Have a great day!!
SOURCE: I have a Lenovo U350
Welcome to Fixya
Looks like the Windows OS is already messed up. You should be able to boot the computer to safe mode to troubleshoot the issue. In your case, it is not booting up to safe mode then the only way to use your computer again is to restore it from the factory default state. If you want to do that, just turn off the computer then press the ONE KEY button located beside the power button then follow the on screen instructions.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
If you are running Safe Mode because you cannot get into Windows, you may want to first try
loading the last known good configuration.
To
get into the Windows 2000 / XP Safe mode, as the computer is booting
press and hold your "F8 Key" which should bring up the "Windows Advanced
Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note:
With some computers, if you press and hold a key as the computer is
booting you will get a stuck key message. If this occurs, instead of
pressing and holding the "F8 key", tap the "F8 key" continuously until
you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode
- If after several attempts you are unable to get into Windows 2000 or
Windows XP Safe Mode as the computer is booting into Windows, turn off
your computer. When the computer is turned on the next time Windows
should notice that the computer did not successfully boot and give you
the Safe Mode screen.
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once
you're done in Safe mode if you want to get back into Normal Windows
restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To
get into the Windows Vista and Windows 7 Safe Mode, as the computer is
booting press and hold your "F8 Key" which should bring up the "Windows
Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note:
With some computers if you press and hold a key as the computer is
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
