Netopia 3-D Reach  (TER/GUSB-N1) (TERGUSBN1) 802.11g/b Wireless Adapter Logo
A
Anonymous Posted on Sep 24, 2013
Computer shows blue screen and freezes up computer
Abed
Level 3:
Master:
Sergeant:
  • Master 158 Answers
  • Posted on Nov 19, 2014
Abed
Master
Level 3:
Master:
Sergeant:
Answers
158
Questions
0
Helped
901099
Points
1016
Try connecting to another USB port and if that does not help try reinstalling the latest driver and if that does not help then your device needs to be replaced.
Imac g4 freeze restart
This is a sign of memory issues with your Mac. Replacing the memory should not be very expensive.
tip
Laptop keeps shutting down with a Blue Screen
That seems for no reason, you computer shut download displaying a Blue Screen frequently. Learning "what is Blue Screen" and "why it happen" is essential. laptop keeps shutting down with a Blue Screen due to various kind of reasons. However, we can pay attention to the most common causes. With basic learning, you can troubleshoot computer crash problem yourself.
There is a misunderstanding that Blue Screen is a virus. In fact, BSOD is is known as a colloquialism used for the error screen displayed by some operating systems. The cause could be hardware and software relate. Computer experts provide us a result that shows the average causes of Blue Screen.
50% are the results of software incompatible or corrupt.
30% caused by virus. In this case, your laptop always gets freezing.
Other causes should be system bug and hardware failure.
It is difficult to repair the hardware. You have no choice but replace it. Here, we only talk about the system bug and software problem. The diversity of the cause makes us confused. However, fixing registry error is the easiest way to solve the problem. Registry is the database of Windows. It was designed to manager computer setting. Everything happened on your laptop is relate to the registry. Fox example, virus programs install on your computer and modify the registry key making your PC very slow.
Laptop keeps shutting down with a Blue Screen? It is recommended to use a registry cleaner. The program will diagnose errors accurately and clean up them in seconds.
on Sep 15, 2010 • Computers & Internet
I have a PB6200 BenQ projector. When the computer starts up it shows the BenQ and then shows the windows computer startup screen until it finally fully boots up. Then the projector does not show what is...
There's a display "toggle" sequence on your computer to send the signal to your external post (VGA?). Look at the Function keys (top row) for a screen icon. Hold Fn key down and press that Function key (on Dell, usually F8). You should get an indication on your screen of which outputs are active -- look for BOTH.
When i boot into the operating system which is win7 machine freezes and shows up a blue screen.when i placed the hard disk into a usb external case and connected it to a pc a message box showed saying i...
Get a windows 7 install or repair disc. Make sure your pc boots from the disc drive. When you get to the installation screen tick REPAIR YOUR COMPUTER. Then select the installation you want to repair and choose STARTUP REPAIR.
2helpful
Infocus X1 picture freezes and dissapears and then comes on again
your display settings may be off, so change settings to factory reset and you may have to drop the resolution on your computer. you may also have a bad cable, so try a different cable.
Screen Freeze Consistently
THink its time for a new laptop
GPX player just showing a blue screen
IM NOT SURE WITH THE ERROR THATS WHAT IM TRYING TO FIX ON MINE!
BUT JUST HIT THE RESET BUTTON ON BACK IT SHOULD TURN OFF
Y do i get a blue screen
It sounds like you have a boot sector virus.
Top Netopia Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
