Serger started sewing more slowly and then stopped- computer display read "overload" which I've never seen before. The handwheel feels really tight and hard to move. I cleaned it all, oiled the spots as per the manual and then rethreaded it- it started back up but then stopped again.
Any help you could give me would be greatly appreciated!
this type of problem related to "overload protection" the motor can't overcome the load work,then it would able to stop your machine,theres problem on motor assembly try to check the carbon brush.if worn out replace,handwheel are couple to motor pulley inside machine.there an opening for the belt.if you want to check it loosen bolt cover,have move the belt you can figure why handwheel moving tight.if you realease the belt handwheel will move independently but handwheel is connected to a cam shaft w/mechanical link connected such as gears,cam and bushing that
can also suspiciuos of obstruction can came there.take this to service center if trouble link to mechanical problem.have a nice day
rate me and thank's
http://www.sewingresourcesonline.com/product/PD1234
I have the same serger. The produt link posted above is an awesome intrustional dvd on learning the cover stitch.
Overload message: it emits a allarme (beep) and stop. Can be rotated by hand
Or is the problem? model 936
