hello
first unplug the fridge freezer from the power outlet.
Look for the bulb compartment or socket where the light bulb is located
then remove the bulb and then install a new one .Ensure replacement bulb is of the correct type and wattage
then test the bulb
Unfortunately, the SJ-BB05DTXWF has LED lighting. Those aren't user replaceable. https://www.currys.co.uk/products/sharp-sjbb05dtxwf-6040-fridge-freezer-white-10218761.html provides this specification information.
Only incandescent bulbs are user replaceable in most refrigerators. On the Sharp SJ-B1237M00X model, there is an incandescent bulb behind a cover that will move when you press on the bottom.
Try pushing the sides of the plastic to remove it. Then you can access the bulb. Do not remove the bulb with your bare hand. Use a dry towel because if the bulb breaks in your hand, you have a problem. Unplug the fridge when you do this.
The light bulb on the sharp upright vacuum is accessed by removing the bottom rug plate. Once that has been removed I believe there is two screws to remove and the light bulb and socket will pull out through the bottom.
Make sure you unplug fridge from wall power socket,remove bulb cover if one is fitted.Carefully twist or gently try to unscrew bulb. If successful take bulb to electrical parts shop and buy a new one.You may of course use your Fridge until you buy a new lamp,Refitting is simply the reverse of removing bulb.Good Luck!
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The light bulb is usually located in the center top of the fridge box, you may need to get on your knees and look up to see it. They usually just screw out, in case there is a plastic cover, just squeeze it and remove it. The replacement bulb can be found at Walmart or KMar it is call Appliance Bulb.
Usually the light bulb base is a screw, to remove it you need to rotate it clockwise (facing your fridge). I highly recommend you to use a towel to handle the lightbulb for safety reasons.
If you are replacing it, please be aware that you should use a 25W or 45W light bulb.
