Pioneer AVH-P4000DVD Monitor Logo
A
Anonymous Posted on Sep 24, 2013
Usb flash error 23 - Pioneer AVH-P4000DVD Monitor
Pioneer DEH-P8400bh USB error 23
In the manual Error 23 states the USB stick is not formatted with the FAT16 or FAT32 filesystem, which is the only supported filesystems supported on the unit.
Modem name: MMX310G 3G USB Manager At port: COM 23
IMEI: 910532501150347
Please provide the nck code for MMX310G 3G USB Manager
Thanks
[email protected]
Error code 23 - Pressure Switch did not open My Carrier Weather Maker Furnace is flashing an error code 23- Pressure Switch did not open( Obstructed Pressure Tubing/Pressure Switch). What should be done...
Its probably a bad pressure switch where the contacts did not open when the exhaust fan shut off. Check the pressure switch ports and verify there not blocked.
8helpful
3answers
Error 23 when connecting USB hard drive to car
You must format the USB to FAT32..! Works for me!
4helpful
2answers
Error 23 when I try to play music from my new flash drive
I have found that cruzer flash drives uses a special format with it's own software. I found a format utility to make it the FAT format for a friends cruzer..
Flashing error message C:31:23
Hi Jazzy,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
48helpful
7answers
Pioneer AVH-P5000DVD stereo USB Error 23
I had the same problem with my Pioneer AVH-P4000DVD. Just got my 16GB sandisk micro cuzer in the mail from Radio Shack. Here is what I did to solve it:
  1. Copied all the files that came with the Sandisk device to another location (in case I need them again)
  2. Copied all the music I had put on the Sandisk since I got it to another location
  3. Using a Windows PC, I right clicked on the drive in Windows Explorer and selected "format"
  4. I re-formatted the cruzer mini to FAT 32, default size (yes, I know it was FAT 32 already)
  5. Copied the music back to the cruzer mini
  6. Plugged it into my radio and it works GREAT! instant access to any track
Before you do this: Reformatting the drive also gets rid of the software that makes the cruzer mini copy files super fast. It will take a lot longer to copy music to the drive. For me this is no big deal as the only reason I bought the drive was to put a bunch of music on it and then leave it in my truck.
Top Pioneer Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
