Question about Life Fitness Exercise & Fitness
We have Lifefitness 9500HR Treadmill. I am getting a Bad Controller Error. We have two 9500HR models. I swapped out Controller, with working 9500HR and still get Error. Keeps going into Notify Maintenance. Also with same unit, when pressing incline lift up, but pressing decline lift continues going up...Thank you appreciate any input
  • Life Fitness Master
  • 918 Answers
I would suggest swapping the consoles to see if the problem follows. If this does not help you figure it out, you are more than likely looking at a wiring issue.
Posted on Apr 23, 2014
5 Suggested Answers
SOURCE:
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Posted on Jan 06, 2010
gymtech
  • 18 Answers
SOURCE: Hi! i have a life fitness 9500HR treadmill and it
Unplug the treadmill . Remove front cover. On the right hand side if you are facing the front - in the siderail is a white switch that tells the treadmill it is all the way down. Check that it is in place and clean.
If you plug the treadmill in.{Do not touch any thing in the motor compartment} When you press start it should go all the way down [home] to contact the switch. You can also see the lit motor turn at this time before the belt will move it must be all the way down.
Posted on Feb 09, 2010
bwinton
  • 83 Answers
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Posted on Apr 29, 2010
maxtreadmill
  • 832 Answers
SOURCE: treadmill stop then display an error speed
If the is a Next Gen unit need to enter Diagnostic menu by pressing and holding pause then press clear twice. Continue to hold pause until until read service menu. press any arrow up and select system test ,then press enter the display will begin to automatically scroll thru available options. press enter to access Main Motor Module the next window will be Speed Automatic.
Upon entering this test mode you will able to check the drive motor and motor control board. By using the the speed arrows you will be able see the actual speed if functioning if not it could possibly be the speed sensor or wire harness ( SIMPLE CONTINUITY CHECK WILL RULE IN OR OUT THE HARNESS ) and point the problem. Now if their is no belt movement then hit clear and proceed over to SPEED CONTROL ERRORS hit enter this test allows seeing the motor controller conditions that are being displayed on the motor controller display if any of these come up then the controller need s to repair or replaced:
Max Temperature, Maximum voltage, Fault Line 1 error, Static current trip and dynamic current trip ( this also can a running belt tension this can result in a cannot obtain speed error message ) hit clear to get out of diagnostic once you eliminated the problem. Good Luck!!!
Posted on May 21, 2010
Bad Controller Comm Error. I swapped out Controller but still get same error, any suggestions?
i recommend to replace the control board. This is very critical matter for the electronic machine. see the diagram attached, How the controller motor hast the 80 of control of machine.
go to www.fitnessrepairparts.com and get it
Sep 23, 2013 | Life Fitness LifeFitness 9500HR Treadmill...
Motro controllar com bad
Check out www.carolinatechnicalservices.com for LifeFitness motor controller repairs.
Jun 08, 2011 | Life Fitness 9500HR Next Generation...
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
Treadmill stop then display an error speed
May 21, 2010 | Life Fitness 9500HR Next Generation...
Apr 28, 2010 | Life Fitness 9000 Next Generation...
How do I access the service menu on a lifefitness 9500HR treadmill?
To get to the service menu start by pressing the pause button and keep it held down as you hit the clear button twice. The treadmill will reset and go into the service menu, and now you quite pressing the pause button.
Mar 31, 2010 | Life Fitness 9500HR Next Generation...
Manual for lifefitness 9500hr treadmill old modle
Just call Life Fitness and they will send you one via e-mail attachment.
(800) 351-3737 between 8 a.m. and 5 p.m., CT Monday through Friday.
stephen
Aug 01, 2009 | Life Fitness 9500HR Next Generation...
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Mar 12, 2009 | Life Fitness 9500HR Next Generation...
Exercise & Fitness Logo
192 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
