Microsoft Windows XP Professional Logo
A
Anonymous Posted on Sep 24, 2013
My game(GRID 2) won't start without handler 4 common dll
3helpful
What's your problem?Except handler 4 common msvcrt.dll free download
it is usually caused when your computers registry system contains errors or when certain system files are missing or broken; Msvcrt.dll problems are a sign of a very unhealthy computer registry...
Download a free program called cCleaner- it is really easy to use and does a great job of cleaning up your registry- and did I mention it's free-
http://www.ccleaner.com/ccleaner-20
scroll down the page and you will see the where to download it...
Easy, fast and painless-
Hope this get you fixed, good luck, please leave rating, thank you kindly
It has DINPUT.dll error
Dinput.dll errors usually appear when a game or other software program is started. and are caused in one way or another by an issue with Microsoft DirectX.
The dinput.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, dinput.dll errors usually show up only when using these programs.
Solutions:
1. For Dinput.dll not found. Reinstalling Direct X should fix this.
2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the dinput.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX 11, DirectX 10, and DirectX 9 files, but they run side-by-side without problem on all of these operating systems.
3. Assuming the latest DirectX version from Microsoft doesn't fix the dinput.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with dinput.dll and a reinstall could do the trick.
Restore the dinput.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your dinput.dll error, try extracting the dinput.dll individually from the DirectX downloadable package.
4. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Here is a good link for DirectX info on how to download and install:
http://support.microsoft.com/kb/179113
15helpful
2answers
Missing mss32.dll, im using windows 7 ultimate
MSS32.dll is used quote commonly in various games. A fair number of games rely on Windows having this dll file already installed to an indexed folder such as c:\windows or c:\windows\system32. If you are missing this file you should try reinstalling the game first as there are multiple versions of it - my online research shows 3 distinct versions for games like GTA3/4, Zoo Tycoon, and Counter Strike. It also appears it might be used for some graphics programs.
If reinstalling the program that is giving you this error you might try downloading a common version of the DLL file from http://www.dll-files.com/dllindex/dll-files.shtml?mss32. You should first try putting the file in the 2 folders mentioned above, then start putting it in the folder with the program that is claiming the file is missing (for instance: C:\Program Files\Valve\Steam\SteamApps\<account name>\counter-strike source\bin).
I hope this helps!
2answers
I got problem with d3dx9_29dll was not found.anyone could help?
There are quite a few different ways that d3dx9_29.dll errors may show up on your PC. Some of the more common d3dx9_29.dll errors are listed here:
  • "D3DX9_29.DLL Not Found"
  • "File d3dx9_29.dll not found"
  • "Error while starting game executable - couldn't load DLL file d3dx9_29.dll."
  • "D3dx9_29.dll is missing"
  • "D3DX9_29.DLL is missing. Replace D3DX9_29.DLL and try again."
  • "D3dx9_29.dll not found. Reinstalling the application may fix this problem."
  • "Missing component d3dx9_29.dll"
  • "This application failed to start because d3dx9_29.dll was not found!"
D3dx9_29.dll errors usually appear when a software program, most often a game, is started. Occasionally, d3dx9_29.dll errors will display after a game is loaded but right before the game begins. Unlike many other dll errors which can have complicated causes and fixes, d3dx9_29.dll issues are caused in one way or another by a single issue - some kind of problem with Microsoft DirectX. The d3dx9_29.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, d3dx9_29.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not, under any circumstances, download the d3dx9_29.dll DLL file individually from any "DLL download site." There are a number of different reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded d3dx9_29.dll from one of those DLL download sites, remove it from wherever you put it and continue with the following steps.
1. Restart your computer if you haven't yet done so.
The d3dx9_29.dll error might be a fluke or one-time issue and a simple restart could clear it up completely. It's unlikely this will fix the problem, but restarting is always a good first troubleshooting step.
2. Install the latest version of Microsoft DirectX 9. Chances are, upgrading to the latest version of DirectX 9 will fix the d3dx9_29.dll not found error.
Note: Microsoft often releases updates to DirectX 9 without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: Are you a Windows Vista user with DirectX 10? Your game or program may still need DirectX 9 files to run properly so give the installation a try. Don't worry, both versions of DirectX can be run side by side in Windows Vista.
3. Assuming the latest DirectX version from Microsoft doesn't fix the d3dx9_29.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
4. Uninstall the game or software program and then reinstall it again. Something may have happened to the files in the program that work with d3dx9_29.dll and a reinstall could do the trick.
5. Restore the d3dx9_29.dll file from DirectX 9. If the above standard troubleshooting steps haven't worked to solve your d3dx9_29.dll error, try extracting the d3dx9_29.dll individually from the DirectX 9 package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
1helpful
I got a remote controll helicopter and when I installed the software for the Flying Model Simulator, it brings up an error saying that D3DRM.DLL IS NOT LOADED.. What can I do to run this program so I can...
The D3DRM.DLL file is the Dynamic Link Library for Direct3D Retained Mode, an older DirectX display technology that was not included with Windows Vista. Direct3D is used to render three dimensional images in applications where performance is important; the most common examples of which are games, CAD drawing programs and graphics editing software.
The error message displayed varies by program, but some some of the more common ones are:
  • "Failed to initialize Direct3D with current settings"
  • "Cannot find the file d3drm.dll"
  • "This application has failed to start because d3drm.dll was not found"
  • "D3DRM.dll is not loaded"
This error is usually a sign that the d3drm.dll file has been deleted, corrupted or altered in such a way that makes it unusable to your program.
To fix errors like this:
1. Install the latest version of Microsoft DirectX. It will fix the d3drm.dll error.
2. Uninstall the game or software program and then reinstall it again.
3. Update the drivers for your video card.
4. If it doesn,t work copy d3drm.dll file to the system folder.
Hope it helps.
2helpful
2answers
D3drm.dll promblem
Go to the following site, copy the d3drm.dll and save it to your c:\windows\system32 folder
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
