SOURCE: memory stick error
Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck
SOURCE: sony cyber-shot dsc-w55 flash doesnt work
hi
the flash doesnt flash anymore, you may need to replace th bulb for that. the yellow light means its a warning that the bulb is wor out.
hope this helps
SOURCE: Flash stopped working on Sony Cybershot DSC-H10
What a coincidence. Even my camera is 14 months old & I too have exactly similar problem.
Can some one throw some light on this pls??
