KitchenAid 24 in. KUDS25SH Built-in Dishwasher Logo
A
Anonymous Posted on Sep 23, 2013
Kitchenaid recall kuds301vwh3 - KitchenAid 24 in. KUDS25SH Built-in Dishwasher
Where can I get an Kitchen Aid A-9 burr grinder repaired?
Softly Scrambled: Kitchenaid A9 Grinder Refurbishment.
softlyscrambled.blogspot.com/.../kitchenaid-a9-grinder-refurbishment.ht...
Mar 1, 2014 - This is an original A9 from the days when Kitchenaid was owned by Hobart. ... Yes, it worked and would grind coffee, but the motor seemed to labor and the grinds were ... I am now doing this for mine, but I can not for the life of me get to the bushings. Does ... I don't recall a ball bearing from repairing my A9.
KitchenAid Burr Coffee Mill KCG200 (aka A-9) - Automatic Washers ...
www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?44466
Jan 13, 2013 - 49 posts - ‎12 authors
I'll definitely use that cleaning method if I can't get the grinding mechanism .... I'd try lifting the lower burr assembly out with the aid of two flat ...
Kitchenaid A9 Coffee Grinder - HubPages
hubpages.com > Food and Cooking > Beverages
Sep 20, 2013 - Where can I buy a retro Kitchenaid A9 Coffee Grinder? ... are paying for (is it new in box, has it been used for 20 years, or does it need repair).
KITCHENAID A-9 INSTRUCTIONS MANUAL Pdf Download.
Need to replace the adjuster and need instructions how all the parts go together.
Replacing Adjuster Wheels on a Kitchenaid Dishwasher ...
? 2:50
https://www.youtube.com/watch?v=ClCHpDL--Gw
Jan 26, 2014 - Uploaded by natifamily
Replacing Adjuster Wheels on a Kitchenaid Dishwasher. natifamily ... Dishwasher Top Upper Rack Adjuster ...
Whirlpool, Kenmore, KitchenAid - Dishwasher Replacement ...
KUDS30IXWH2 recall ?
I am not sure if it has been recalled, but it is the worst dishwasher I have ever owned. KitchenAId used to be synonymous with quality, in my opinion, not anymore.
A $700 dishwasher shouldn't need the main control panel and module replaced 3 times in 2 years. This is a part that costs about $350 plus installation to replace.
The part almost always seems to be backordered and therefore you are without the dishwasher for weeks while one of these come in, then you have to wait for a service technician to install it.
What really annoyed me is that after a call to the "Whirlpool Cool Line" I still haven't heard what they as the manufacturer are going to do to make the problem right.
I had a better experience with the Sears customer service line, this is where I originally purchased the dishwasher. When I called their executive resolution team and they saw that this was the third time that this machine was being repaired for the same issue, they offered to replace the machine. Kudos to Sears! Their customer service in this case is as good as a Nordstroms, Neiman Marcus, or Saks Fifth Avenue.
In my opinion stay as far away from this dishwasher as possible!
Door latch wont hold door closed
Complain complain complain to Kitchenaid. They know this is a design flaw and should recall this product! Kitchenaid used to be high end.
My KSRB22FKBL14 KitchenAid side-by-side fridge caught fire (start relay on compressor). I understand that KitchenAid fridges are made my Whirlpool/Maytag. Whirlpool/Maytag has a HUGH recall right now...
the problem is the same as maytags but it may not be a recall model . relay is white . the new style are blk . you can purchase the new relay kit.( what is a start devise .kit / changing it will solve the problem .. also you should contact whrlpool .. mm
Was heating something when it made a zinging noise and now thothing is working no lights or power
My same microwave did this about a week ago... repair people said the part that surrounds a fuse had burned through. 350 to fix it, I am considering just getting a new one since I have now found that mine has had a replacement part fix done after a recall on this microwave. If you have not read the recall info you can find it easily by doing a search for Kitchenaid Microwave recall. There will be a small green square sticker by the serial number if yours had had the recall repair done already. Mine had but I still have had this recent problem even after the recall repair.
2answers
Multiple replacement of Microwave door springs
KitchenAid Architect Series KEBC107KSS Electric Single Oven problem error F1E7
1helpful
Kitchenaid oven KEBC107KSS03 won't heat after cleaning cycle.
I have a kitchenaid oven # KEBC107KSS03. When I set the temp to 400 the buzzer goes off saying the temp has reached the desired temp, the temp is only 250 and will take another 20-30min to reach 400.
thanks for your reply
Oven glass shatter on kgst307gwh0
You would need to contact Kitchenaid about any possible product issues
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
