That code that the game is asking for is the product key of the game. This key is somewhere in or on the box the game came in. Input that code into the boxes and the game should proceed to installing. Hopefully it works out!
You can use the same key for activation.If you have registered a mynorton account, your key will be saved there. If you no longer have the key, you need to contact Norton Customer support.
It sounds like your system has corrupted. Put your instal disk in. Start
your mac up and hold down the c key. Once it has started check that the
hard
drive exists by go to the menu bar and selecting the disk utility. If
the hard drive shows it means that it is okay. Then run the disk utility
check
drive and then run the repair permissions. You can then try restarting,
if it
works then you are back up and running again. If it does not you will
need to reinstal your system. You do this by starting up with the instal
disk holding down the c key and run the instal script. To keep your
hard drive contents you MUST use the preserve users instal which will
come up as an option. Do not reformat the hard drive as this will wipe
all your information.
If you have been running time machine as
your backup operation you could instal a totally clean system and then
select the time machine backup once the new system has been laid down
using the migration utility in the utilities folder within the
applications folder.
If
your hard drive does not show up the hard drive is probably a goner
and you will have to purchase a new hard drive and instal a fresh
system.
Two possible things are wrong either your hard drive
has failed or your system has corrupted. Put your instal disk in. Start your mac up and hold down the c key. Once it has started check that the hard
the hard drive shows it means that it is okay. Then run the disk utility check
drive and then run the repair permissions. You can then try restarting, if it
hard drive contents you MUST use the preserve users instal which will come up as an option. Do not reformat the hard drive as this will wipe all your information.
If you have been running time machine as your backup operation you could instal a totally clean system and then select the time machine backup once the new system has been laid down using the migration utility in the utilities folder within the applications folder.
If
your hard drive does not show up the hard drive is probably a gonner
system.
press menu then 1570 opens secret menu then go to provider c******s or n*hell or whoever you must use your provider enter key no in line no. 1 its the 00 line then use remote to imput the no. and letters the colour keys and the audio /pause info key when you have oo line done press ok to store then put in o1 line and the o1 line code after you have oo line in and saved you use the same line only put o1 in then the o1 code in then save again make sure your emu is turned on that should do it
I AM CURENTLY AWITING ANOTHER REBOOT DISK AS THE MANUFACTUERS OF THE LAP TOP SAID IT MIGHT NEAD THE FULL INSTAL OF VISTA HOME BASIC AND NOT JUST THE REBBOT PROGRAM VERSION I GOT WITH THE PC. AS THIS DOES NOT INCLUDE THE START UP SETINGS THAT CONFIGS THE BIOS TO USE VISTA. ( I DIDNT UNDERSTAND THIS TILL I ACTURLY GOT INTO THE BIOS) THE NEW DISK WILL ASLO INCLUDE A NEW PRODUCT KEY THAT DOES NOT NEAD TO BE CONFIRMD VIA INTERNET TO USE AS IT IS JUST THE BASIC VISTA PROGRAM THAT SHOLD ALOW ME TO INSTAL MY UTILITIS AND DRIVERS TO INSTAL THE MODEMS AND OTHER SYSTEM FILES. WHEN I ORIGANLY GOT THE LAP TOP IN 2007 THE REBOOT &RECOVERY DISKS ONLY HAD THE SET UP PROGRAMS THIS ALOWS YOU TO INSTAL VISTA OPERATING SYSTEM BUT NOT ALL THE PROGRAMS WILL WORK AS YOU NEAD TO DOWNLOAD THE FULL SYSTEM SETINGS. SO JUST TO LET OTHERS KNOW IF YOU GOT A LAP TOP OR PC THAT ONLY HAD A REBOOT DISK TO CHEK THAT IT IS THE FULL VERSION ( NEW VISTA RECOVERY 2008 ) AND NOT THE 2007 ONE
