I have a phone that got switched to pulse and now can't get it back to tone.
Many thanks to Fafa, your answer is very useful to me since I have cordless phone model 27923GE1 and your answer is exactly to my point. ^_^
Dialing mode
If you cannot make calls, change this
setting according to your telephone line
service. The default setting is “Tone”.
“Tone”: For tone dial service.
“Pulse”: For rotary/pulse dial service.
1 {MENU}
2 {V}/{^}: “Set tel line“ i {OK}
3 {V}/{^}: “Set dial mode“ i
{OK}
4 {V}/{^}: Select the desired setting.
5 {OK} i {OFF}
We have alcatel EPABX with 1+2 confrence call facility. Is there any hardwar or software to get it upgeaded for facility of call bridge wherein we can have 6 parties on call conference. What will be the approx cost and is this feature a good solution and work trouble free. Please advise.
I got the same problem. I searched everywhere and got the manual at Tomson. Since it is so painful to me, I would take the pain to write this and share to you. Now, for GE 2-6920R, it's easy:
Tone:
1. Make sure the phone is OFF
2. Press and hole the CHAN button for 2 seconds until the phone beeps
3. Press TONE* button. The phone will phone again to confirm the change.
OK. I did searched a bit more to get manuals for my other GE cordless. You can get it from GE's site here. Just search the product, go to the details, then go to manual and spec sheet. The link is here.http://thomson-asia.ru/Thomson_asia/GE/g...
To select the dialing mode TONE (preset) or PULSE. Make sure the handset and base unit are not being used. 1. Press [VOICE ENHANCER], then press [8]. -The VOICE ENHANCER indicator flashes. 2. To select PULSE, press [1]. OR To select TONE, press [2]. 3. Press [VOICE ENHANCER]. -The handset beeps and the indicator light goes out.
No idea what type of phone you have. Most have a switch labeled pulse/tone. If this is an old multi-line phone system then the memory battery is bad and you had a power outage setting the system back to default settings.
I found a manual from AT&T that had the information I needed. Thanks!
SOURCE: switching from pulse to tone
1)Make sure the phone is OFF (not in TALK MODE) 2)Press and hold the PROG buton until you hear a beep. The TALK button will flash while in this mode 3) Presd the TONE (*) button to select Tone Dialing or press the PAUSE (#) button to select Pulse Dialing 4) Press the PROG button again. The unit beeps to confirm.
SOURCE: Radio shack phone c-4210
in GE models:
TONE/PULSE DIALING
To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
I have a Southwestern Bell GH5810 Cordless Phone and through my children playing with it, it has been switched to pulse. I cannot figure out how to get it back to tone.
GE 2-6920P cordless 900 Mhz somehow switched itself to pulse dial. No Idea how it happened or how to switch it back. Tried to talk to GE Thompson, their runaround makes Dell service look good. Who keeps manuals ... Who gets a manual? Where am I ???
I BOUGHT A NEW VTECH 2650 EXTENSION PHONE AND ALL IT DOES IS SAY SEARCHING FOR SERVICE
I cleaned up my ge cordless phone 2-6920R. Some how the setting changed to tone. I need to change it back to pulse mode. What is the procedure
My phone started dialing in pulse tone one day and I can't figure out how to change it back?
Synergy 2110 handset will not ring, also it does not auto answer when lifted from its cradel. We have lost the manual and do not know how to reset it
My Panasonic cordless phone KX TGA 101S suddenly has an old fashioned rotary dial tone. How do I switch it back to normal? It is also affecting my voice mail retrieval. Please help.
I have easy alctel phone set. How to handle ISD conference calls, when I follow IVR messages and use codes calls get cut. Do I have to use * key for which IVR message doesnt speak about. Olease help me.
I have the same problem with my Panasonic kx-tg5634 didgital 5.8. Can not figure out how to change it back to tone. Just switched on me one day and can not find anything in the manual of how to fix this.
Any help would be greatly appreciated.
