Scanner error 12 how to splve
You can use the service manual to solve this problem
http://www.nodevice.com/manual/laserjet-m1005-mfp/get83409.html
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
SOURCE: How can resolved Scanner error 12 in Hp Laserjet
Try to uninstall the software of your scanner and reinstall it again. Also
check your cables for loose contacts.
Thank you!
SOURCE: SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
