SOURCE: how can i change my nokia 63 phones arabic
First go to Settings,
then select Personalization Settings,
then select Language,
From there you can find English Language.
SOURCE: i want to change language arabic to english from
I did a google transliteration for LANGUAGE and got the result. Look for the corresponding word in the settings icon and change language to ENGLISH.
Or if you can follow the icons it will be in this order;
MENU>TOOLS>SETTINGS>GENERAL>PERSONALISATION>LANGUAGE(FIFTH AMONG THE DROP DOWN MENU)..Hope this helps...
SOURCE: current language set in arabic.
Since the phone is in another language distinct from English
language, you will have to use the phone symbols as a guide to get to
Language settings on your Nokia E72 and change it to English. This is
because you won't be able to read or understand what's on the phone menu
since its not yet in English language.
Click menu, go to tools. Tools has a spanner symbol. Its the first icon on the second line of your phone menu.
Click settings. Settings, also has a spanner symbol. Its also the first icon on the second line of the Tools menu.
Click General. General is the first on the list under settings.
Click
personalization. Personalization is also the first on the list under
General. It has a paint symbol/icon with red, green and blue dots.
Scroll down by pressing the down navigation button four (4) times and you will get to language.
Click
it and the first option on the list is "Phone language". Press it and
you will see a list of your phone languages, scroll to English and
select it and that would be all.
Follow the above direction and you will certainly get to English language under the phone language.
Good luck.
SOURCE: how to change language on nokia e52 from arabic to english
Hi there
I have found the userguide for the device on :http://nds1.nokia.com/phones/files/guides/Nokia_E52-1_UG_en.pdf
There on page 161 , it stats :
Language settingsSelect Menu > Ctrl. panel > Settings and General > Personalisation > Language
due to be at arabic language may nedd to check the icons on userguide.
I hope this information can help you.Best regards
change the language in nokia E66
1st Go to Tools ( your cell 5th option )
2nd Go to setting ( your cell 5th option )
3rd Go To general ( 1st option)
4th go to renationalisation (1at option)
5th go to language (5th option)
6th go to phone language (1st option)
than open your other language option
100% tested by me
