SOURCE: F7 error
Hi robpris,
My fix for the most common cause of the F7 problem can be found at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with over 1600 folks and most report success.
Please let me know if this works for you. Email me at:
[email protected]
Regards,
Powerman
SOURCE: f7 error in Kenmore double oven
You can find my solution to the most common cause of the F7 problem at the following link:
I have shared my fix with over two thousand unhappy GE customers. Most report success. I hope that it works for you too. Please let me know by sending an email to:
[email protected]
Regards,
Powerman
SOURCE: Kenmore wall oven (model 911.41065690). Works fine
The F7 error code on your oven indicates the touch pad has failed. To repair it you will need to replace the touch pad which is listed as a control panel w/keypad in the parts diagram.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that hold the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touchpad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
good luck
SOURCE: error code f7 on Kenmore wall oven 911.41165791
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
