Nikon COOLPIX L18 Digital Camera Logo
Posted on May 20, 2017
Black Screen I have taken really good care of my camera and it has never been dropped. I went on a Cruise a few months ago and one day into the cruise the screen wouldn't show anything. It was just a black screen. When I took pictures they turned out black too. I am still able to navigate the menus and see pictures on my SD card. Even after returning to Colorado, a dry climate, the screen is always black and taking black pictures. Is there something I can do to fix this problem or should I just scrap the camera?
Gary Camp
Level 1:
Scholar:
New Friend:
  • Contributor 35 Answers
  • Posted on May 20, 2017
Gary Camp
Contributor
Level 1:
Scholar:
New Friend:
Answers
35
Questions
Helped
6555
Points
60
Do more internet searches of your model. Sounds like the sensor chip died. Pretty expensive part. Could have not liked the salty environment or you are just unlucky. Do the search until you give up as there is a lot of info on internet. Cameras are getting pretty cheap now so if it is a little old or cheaper model, you may do better with a forced "upgrade".
5 Related Answers
Anonymous
  • Posted on Feb 14, 2007
SOURCE: camera turns on but lens doesn't work
I had the similiar problem, send it to the Manufacture. They had to replace some parts in it. My camera was under warranty- Best of luck
Anonymous
  • 6 Answers
  • Posted on Oct 16, 2007
SOURCE: Screen
Get on to Nikon and let them know about it, it is a common problem with the S4. They are fixing the 3500 and others for free.
 John.
Anonymous
  • 3 Answers
  • Posted on Dec 23, 2007
SOURCE: black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
  • Follow the URL: http://www.nikonusa.com/email_images/nikonusa/service_advisory/launch_all.html
  • Fill out the form
  • Mail in your camera if it's listed
  • Receive your working unit free of charge
I had the same problem with my CoolPix5400 and this resolved the issue.
Anonymous
  • Posted on Dec 12, 2008
SOURCE: The camera powers on fine, although it has a black screen with no image. What type problem is this and is it fixable or not.
i have the same problem i need help fixing it?
Jeff Marcus
  • 115 Answers
  • Posted on May 08, 2009
SOURCE: Nikon D70s - all photos turn out black
A lot can be happening. Try them one at a time. If the first does nothing, go to the next.
  1. Put the camera in the "auto" exposure mode. Be sure ISO is set at 100
  2. Try a different lens.
  3. Remove the battery for 10 minutes and reinstall.
  4. Go into your menu program and press the "reset all" button to go back to factory specs.
  5. Next change your memory card.
Let me know if we need to go further.
Cruise started to act up. First noticed 'no' resume after stop at traffic light. Turned cruise off, then back on. Set cruise, went about 2-3 miles, cruise kicked off. Then...
It looks to me like a vacuum leak. See the switch at the brake pedal.
look underhood around vacuum leak for cruise control.
look up for bad connector at cruise module underhood
it's a visual check first
3helpful
2answers
Stalls at low speed when in cruise control
You sould have recieved a "recall" notice in the mail about the cruise control for fire and failure issues. they are adding a fusable link where the cruise control harness connects to the brake master cylinder. if you have not had the recall performed yet you should SERIOUSLY consider getting it done, mainly so it doesnt catch fire, but "could" be the result of the failure you've been experiancing! btw, almost ALL Ford vehicles have been affected with the cruise control recall. hope this helps!
Cruise control switch works sporatically.
Faulty product. I install cruise control for 6 years. One of the cables are hooked into the throttle and the other in the vaccuum actuator, since it is electronically controlled actuator, the object itself might be losing it's contents or frankly worded, is taking a nose dive. works much like a brake booster does.
Is it a PID system? (Proportional integral derivative system)
or is it just standard proportional?
That will play a factor.
If you just have one of those cheesy controls (cruise controls), than replace it, obviously it wouldnt of cost much. if it is not, check the actuator and replace it! Replace the Fuse, brush it with wire brush, clean up all connections.
You should be ready to roll!
Good Luck.
1helpful
Cruise control
hello , this kind of problems happened due to wrong connecting with the carbrator , or rearly because of wrong wiring of the cruise control , i hope that helps you and , thank you for using fixya.
5helpful
2answers
2004 Chevy Cavalier Cruise Control Problem
here are two switches that are the usual causes of the cruise kicking out. they are both under the dash. One is the switch for the brake lamps (stop light switch). the other is for the clutch if you have a manual transmission.
if you follow the brake pedal up under the dash you'll find two switches at the top of the pedal. (it may be one switch but I think its two). the top one would be for the cruise control. if the switch is loose it will cause the cruise control to think you're stepping on the brake and that will disengage the cruise control
same with the clutch pedal if you have a manual transmission; if the switch is loose it will indicate you are pushing the clutch pedal in and cause the cruise to kick out
other than that you'll have to check all of the connectors. If it does engage then the fuses and actuators should be good and it would be a loose connector or switch that's kicking it out
also, i assume your speedometer works; if its not then that's your problem as the cruise won't engage under 30 mph
A White Screen!
I had the same problem a few months ago. Best bet is take it to get it fixed. If you still have a warrantey it won't cost you a thing. Good luck!
Can see screen for one second
I had mine for almost 3 years and last month ran into the same problem and i take good care of it. I turn it on it stays on for a 1-3 sec and goes black. can't figure out what it is
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
