Nordic Track Master
- Posted on Sep 23, 2013
Re: TREADMILL KICKS ON AT VERY HIGH SPEED OVER THE 12 PER...
Please RUN the software calibration for easy diagnostic, and fix it.
go under the HOOD motor and see the steps. However see the steps.
The Steps for Newer
Style Console Calibration:
- Locate the calibration area on the rear or
underside of the console (a hole, near the console's center, that goes
through to the electronics board. (This hole should
not have a screw in it.)
- Insert a pencil (eraser end), into
the hole and feel around for the cal button (will click when
pressed).
- Press the button 2 times (with
the pencil eraser). The first click should show CL11 in the
console, the second click should show CL21.
- If the process was done correctly, and
CL21 appears in the console, you are in "calibration mode."
The next few steps consists of pressing buttons on the
console and observing settings. This will not
require any other tools.
- Press ENTER. CL22 should display in the
TIME window and (??) in the SPEED
window.
- Press ENTER. CL23 should display in the
TIME window and (??) in the SPEED window.
- Press ENTER. CL24 should display in the
- Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
- Press ENTER. CL26 should
display in the TIME window. You should then see the letter
"E."
- Press ENTER. You should see "SS"
or "55" in the console.
- Push the STOP/START button. For
safety, at this point, you should step off, or be off, the treadmill.
- Push the ENTER button. The walking belt
should start to move, accelerate to maximum speed, then stop on its
own.
- When the belt stops, the
incline should self test by raising to its highest incline
position, then lowering back down to its lowest position.
- Once the incline test is complete, push
the POWER button 2 times. The unit should shut off and the console
should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or
INCLINE window when the power button is pressed 2 times, the treadmill is
indicating a failure somewhere either in the SPEED or INCLINE (depending
on the window the "F" appeared in). Troubleshooting the failure would be the next step.
