Toshiba Satellite C655-s5090 Notebook Logo
LisaDawn McCabe Posted on Sep 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba Laptop Satellite C655 will not power up
Ben Wabnick
Level 3:
  • Toshiba Master 2,404 Answers
  • Posted on Sep 23, 2013
Ben Wabnick
Toshiba Master
Level 3:
Answers
2404
Questions
Helped
883833
Points
7655
Take out the battery and only hook up the AC Adapter into a normal working outlet. Push the power button and if it turns on then you know the battery is bad. If you still dont get the laptop to turn on then either you have a bad AC Adapter or the motherboard is bad and would need to be replaced.
I have a toshiba satellite C655
some laptops will run with out battery and at some point replace it.
Power port not working on toshiba c655
You had better replace your laptop charger. Even if you go to repair it, it will cost you the same price of getting a new charger. So it is wise to purchase a new one. Here are two for your reference:
$9.99 for Replacement Toshiba Satellite C655 AC Adapter 65Watt 19V 3.42A
$12.90 for Replacement Toshiba Satellite C655 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite C655-S5125
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
11th heading down - Satellite A10. (A10 in Blue)
Go down to the second line, (Begins with A350D in blue), and click on -
C650. (You can also click on C655D )
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
Now what is the problem? Post in a Comment.
1helpful
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Toshiba c655 xp driver
Toshiba lists exactly 170 different C655 Satellite laptop models.
Find your exact Satellite C655 model number then check Toshiba downloads and support at:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
2answers
Do my laptop have a mic toshiba satellite c655
There are different models of Toshiba Satellite C655 (about 9 models) and some have webcam and microphone built into LCD bezel (like Satellite C655-S5052 or Satellite C655-S5113) and some don't (like Satellite C655-S5068 and Satellite C655-S5049).
3answers
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. [email protected] for any additional questions.
2answers
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
