Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier Logo
A
Anonymous Posted on Sep 22, 2013
What is the pre out used for - Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier
Cameron Paton
Level 1:
New Friend:
  • Contributor 45 Answers
  • Posted on Apr 18, 2016
Cameron Paton
Contributor
Level 1:
New Friend:
Answers
45
Questions
0
Helped
9027
Points
73
PRE OUT/PWR IN - (1) Effects Loop - Connect PRE OUT to an effects device input, then connect the effects device output to PWR IN. (2) Multiple Amps - Connect the primary unit's PRE OUT to the auxiliary unit's PWR IN. The primary unit is used to control all auxiliary units. (3) Recording or Reinforcement - Connect PRE OUT to sound equipment's input. Both jacks use a TS (Tip-Sleeve) standard type plug for connections. PRE OUT includes onboard tone shaping.
I am having trouble attaching a microphone to a Yamaha Clavinova CVP-601. Any suggestions?
You can use the Line In jack, but you will probably need to use a mic preamp to raise the mic output sufficiently. You can try using an inexpensive mic from an amateur karaoke system or Guitar Hero etc. If that mic has no 1/8 inch mini phone plug, you can look for an adaptor, or have a tech type person set the mic cable up for you. If you want better quality, borrow or buy a professional vocal mic which uses an XLR cable and adapt the cable to plug into the 1/8 inch Line In jack on the keyboard. As I said, if the mic level is not loud enough, you can use a mic preamp, such as the ART Tube Mic Pre, which you can find used, or on a clear-out for maybe $25 to $35. Use a cable with a 1/4 inch connector on one end and a 1/8 inch connector on the other, to connect the mic pre output to the keyboard Line in. Plug the mic into the XLR input of the mic preamp. This will work 100%. Just adjust the mic preamp level controls carefully.
tip
How to Set up Auxiliaries on a Mixer.
Here are some tips to set up the auxiliaries properly on your mixer:
  • Step1:
Your auxiliaries allow you to send the signal from a channel strip to somewhere else while maintaining the signal on the channel strip. For instance, you can use auxiliaries for monitor mixes for performers in a live environment. You can also use auxiliaries for external effects processors or a number of different situations.
  • Step2:
Set the auxiliaries to pre-fader to allow you to change the level for the auxiliary with the auxiliary knob but not with the channel fader. Most mixers have a "Pre" button that allows you to enable pre-fader mode. If you don't have the button pressed, your auxiliaries are in post-fader mode, which means your channel fader will affect the signal level of the auxiliary output. For monitor mixes, you usually want to use pre-fader so you can control monitor mixes independently from the front of house mix. Some effects processors will be better to run post-fader, though, so don't always rely on pre-fader.
  • Step3:
Send out your auxiliary sends. On the back of your board, you there are the auxiliary outputs. For a monitor mix, you will use these outputs to connect to the inputs of the monitors. When using an effects processor, you will use the auxiliary output to connect to the input of the effects processor.
  • Step4:
Plug in a return if necessary. If you are just doing monitors, you do not need returns to the mixer. When using effects processors though, you need a way to get your effected signal back to your mixer. Take the output of the effects processor and connect that to the return input on the back of the mixer. Now you will have to adjust the return section on your channel strip to get the desired signal.
  • Step5:
Use the auxiliary knob to set the desired level. Once you know if you are running pre- or post-fader, and you have your inputs and outputs all correct, you can start sending signal to your auxiliary output. Turn up the auxiliary knob until either your monitors are set correctly or until you have the desired amount of signal going to your effects processor or other outboard equipment.
The Fender Champion 100 has a Pre Out input. Can that be use to go to a PA system?
The Pre Out and PWR In for a method to insert an effects loop. The output signal from the Pre Out should be line level so you would not connect this to our microphone input on the PA, but preferably to a Line Level input otherwise you would overdrive the PA's input. When you connect the Pre Out, the 1/4" jack may interrupt the signal so you may lose output to the Champion's amplifier/speaker. If this happens, you need to have a return line with the same line level signal plugged into the AMP In to get your sound back on the amplifier itself.
I am unable to send a signal via aux 6 from a channel to ONLY the K sub. The only way I get signal is if I raise the channel fader but then the signal goes to the house L/R mains as well. How do I send a...
It appears that AUX6 is default factory strapped as POST FADER. If you want to change that you will have to disconnect jumper L to A for all channels you want the AUX to be pre-fader and instead connect K to S for the option jumpers. I don't know if this requires soldering or whether they are push on jumpers. These should be available in the back cover. In ADDITION you will have to run the switched pre/post fader switch in the PRE position which will make ALL AUX's that are strapped this way PRE FADER.
2answers
The disk drive on my Yamaha Clavinova CVP-105 acts like it has a disk in it when it doesn't and won't always play pre-formated disks like it used to. Is the drive dieing? Where can I go to get it fixed? ...
Often these drives are continuosly selected by the controller and rotate even without a disk.
These USUALLY use the old 720K disks which are almost impossible to find. The common 3.5 1.44Mb floppies often will not work in these units.
You can SOMETIMES use the 1.44Mb disks by covering the second corner hole AND degaussing the disk with a tape eraser and then reformating the disk in the Clavinova.
The pre-formatted 1.44Mb disks without degaussing SOMETIMES leaves artifacts between the tracks used by the 720K disks that causes problems.
1helpful
I KNOW WHAT THE INPUT 1 AND 2 ARE USED FOR . BUT WHAT ARE PRE OUT AND POWER IN USED FOR. PLEASE HELP ME UNDERSTAND. THANKS DAVE
If one choses to use an external amplifier one takes the pre out and connects that to the in of the external amp.
If one uses an external mixer and wants to use the amp and speakers in the cabinet, the output of the mixer is connected to the Power Amp input.
HINT: DO NOT use these jacks... the jacks have switch contacts that pass the preamp to the power amp and if you use the jacks, sometimes these contacts fail and then you have to open the amp and restore the contacts to get it to work.
The jacks are really weak and EASILY damaged as are the guitar inout jacks if the cables are yanked sideways.
ALWAYS loop your cables through the handle so if they are yanked they don't damage the jacks.
Amp volume drop with flabby bass sound.
1) can happen if the speaker is dying - voice coil defective or magnet needs recharging. happens sometimes with low quality speakers.
2) faulty pre-amp section can reduce overall gain resulting in lower output volume.
3) for old amps dry solders in pre-amp & power amp section can have the same effect.
4) faulty coupling and filter capacitors can severely effect frequency response too.
12answers
PEAVEY ECOUSTIC 112 W/ NO SOUND ----muted?
check all the wire connections
Aug 31, 2008 • Music
Top Fender Music Experts
Sean Wright
Sean Wright
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
