Honda eg3500x starts up fine but will only run choked.
SHUT OFF FUEL SUPPLY AND KEEP VAPORS AWAY FROM IGNITION SOURCE pull the float bowel off carb and REMOVE then clean the orifice in the main jet with a piece of stranded wire or shut off gas and drain the float bowel close drain screw if equipped then get some yamaha carb cleaner and follow directions MAIN JET ORIFICE IS PLUGGED. GOOD LUCK JOE
