SOURCE: Hello. Printer is DCP-7020.
hi!!!
may be there is a bug in your
driver installation try to re-install the driver
SOURCE: Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
SOURCE: Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There
could be a paper jam in the machine. Open the front cover remove the
drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look
for a Jam as well.
Try putting a piece of paper in the manual
feed tray which is right above the paper tray, sometimes on certain
documents the margins are too big and asks to go into the manual feed
slot.
SOURCE: My Brother 5240 laser printer has a red status
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
SOURCE: Hi Today one of the two
Here is an excerpt from pricegrabber.com:
Found that unit will run fine past its replace date just fine. you must reset the unit and look at a message that warns the drum life is coming to a close. We have done more prints like this then when the 1st message appeared. It looked like these would be compatible with dr-510 Not true. What a expensive lesson.
Here is how to reset it:
http://www.ehow.com/how_6875410_reset-toner-count-brother-hl5240.html
Good luck, hope this helps, and thanks for using FixYa.
