SOURCE: Looking for ''Culligan soft-minder meter'' (part# 01-0073-47)
It could be the meter assembly itself. This is the old style with the clear meter dial on the timer mechanism. There were several issues with this meter assembly. You can take the valve off and take it to your Culligan dealer for a "bench test". Also check the meter cable in back of meter assembly. It may have come apart. These parts are only available from Culligan.
RJ
SOURCE: softner model hi flo 2 water volume about half
The flow packs are not opening properly. There may a restriction in the lines feeding the flow packs or the springs/ diaphrams may be bad. I suggest replacing both flow packs and making sure all lines feeding flow packs are free of oxidized iron and debris.
RJ
SOURCE: culligan wg 1035 water softner bine tank will not
The eductor assembly is plugged or the refill restrictor in top of float assembly is plugged. The eductor/injector draws the brine in during regeneration. These need to be cleaned to remove any oxidized iron or sediment . Do you have your owners manual for your Water Gard system?
RJ
