Http://www.pridemobility.com/pdf/Owners_Manuals/INTL_Scooter/uk/UK_Go_Go_Ultra_om.pdf
page 32 lists error codes.
(8 beeps) The scooter's motor is disconnected.
SOURCE: I turn the key on get 10 fast beeps on my GO GO
The Pride Go Go Elite Traveller Plus HD 4 Wheel scooter problem you are describing with 10 fast beeps is that the scooter has "exceeded the push or roll away speed limit" (the scooter service manual is written by an engineer). The second symptom you describe is that you could get the scooter to drive by turning it off and on. By resetting the controller you were able to get the scooter to work for awhile.
This scooter has either an S drive controller or R series controller which has gone bad. By running the serial number you can call the manufacturer and identify which type. The part runs about $500 retail. It may be covered under warranty so it is advisable to call the manufacturer and run the SN first. Pride Mobility Products is at 1 800 800 8586. They can direct you to a local dealer for warranty repair.
While under the rear electronics shroud cover inspecting the controller check for burnt or melted wiring harnesses and connectors and replace those also. The rear cover has velcro attached inserts and well hidden screws that need to be removed first. An experienced tech can do the work in under an hour or you can save some money by doing the repair yourself. If I remember correctly all you need is 2 different size screwdrivers and an open end wrench for the nuts (all metric hardware).
Hope this helps.
SOURCE: New batteries, fully charged, still wont work
I have the book if you can figure a way to post you email without getting too much SPAM. Be sure the charger is un-plugged, and that the free wheel lever is engaged.
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
SOURCE: Battery fully charged, buzzing sound when i try to
check the FREEWHEEL LEVER at the rear of buggy to make sure it in the drive position, if you can push the buggy it not in drive mode.
SOURCE: my scooter will not move i just put new batters on
Make sure that the manual brake/freewheel lever is in the drive position and that there are no flashing lights on the controller. If both of these issues are OK and the scooter still will not, move, contact the manufacturer at 800-800-8586 for assistance.
