SOURCE: freezer only cools to 40 degrees
check to see if there is ice built up on the inside back if there is it may have defrost problems or if part of the back has ice it may be low of freon
SOURCE: frigidaire upright freezer MFU20F3GW7 (model)runs
Clean cooling coils....throughly. Check door seals.
SOURCE: I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
stopped up drain,tear in gasket,not going into defrost soon enough
SOURCE: Frigidaire MOdel LFFU1765DW9
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Hey Joe, thank you for your inquiry!
I see that you need assistance installing the door lock on your Frigidaire freezer, FFU14F5HW. I was able to locate the parts schematic for you and on page two it provides you a picture of the components for the door lock. I hope this information helps you with your part installation. -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/StCloud/5995626933.pdf
Hey friend, thank you for the post!
I understand that you are searching for what type of freon is used in your Frigidaire freezer, FFU14F5HW. Based off of that model the freon would be 134A. Hope this information is helpful. -Matt
