GE Spectra JBP78 Electric Kitchen Range Logo
A
Anonymous Posted on Aug 29, 2017
GE Range Model JBP24GSAID Serial #GL204138G. The Baking element in the stove is not heating. Broiling element and all other functions of the stove work fine. I have unplugged the unit from the wall and reattached without fixing it. It appears that the baking element is bad and I will need to replace it. Anything else to consider before ordering the part and fixing it myself?
Chris Huff
Level 3:
Top Expert:
  • GE Master 6,289 Answers
  • Posted on Aug 29, 2017
Chris Huff
GE Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2019615
Points
74913
Could also be the clock / control. You can ohm out the element with a meter to determine if element is bad.
2 Related Answers
Anonymous
  • 447 Answers
  • Posted on Nov 16, 2007
SOURCE: GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Anonymous
  • 1543 Answers
  • Posted on Aug 29, 2008
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
tip
Broiling and baking element in my electric oven are not heating.
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in series on the circuit from electroning oven control to elements. The probe will control both baking and broiling element, opening the circuit when limit temperature is reached.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
7helpful
3answers
The oven wont heat up.
Hi.
Since the oven has two heating elements, if the oven does not heat up on any condition, and both broiling and baking element are not working, then the most common fault causing the problem is a faulty temperature probe.
The temperature probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electronic oven control to baking and broiling element.
The temperature probe is tested reaching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
1helpful
While baking my wife noticed sparks coming out of the baking element or coil. can we continue to use the stove top or should we leave it unplugged.also how much does it cost to replace the element
It sounds like the element shorted out and needs replacement. I would not continue to use the oven, although it should be ok to use the stove.
It's difficult to say what a new element plus installation will be, but you can call around and get estimates. Have the model number, type and serial number available if possible before you call.
2answers
Bake or broil elements won't work.
First,go to the electric circuit panel. Turn the range breaker OFF then back ON. If that does not correct the problem you will have to replace the electronic control(clock) for the oven.
2helpful
Baking part of range not working
If it's electric, it could be the element or the control. If it's gas, it's probably just the bake ignitor. The only expensive of these is the control.
Baking element
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
1helpful
2answers
GE Electric Range
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
