SOURCE: How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
SOURCE: West Bend 36 cup coffee maker amounts
It's a percolator. Use about 1 heaping teaspoon of coffee per cup. Each coffee pot is different. You will have to adjust the amount of coffee for what you like.
SOURCE: West Bend 33600 doesn't heat - how do I test thermal fuse?
Yes, if you have no continuity across a thermal cut-off, that means it is blown.
SOURCE: Need a coffee (not espresso) carafe for West Bend 55129
This page at the West Bend parts site shows all the parts, prices and you can even download a manual if you need it.
SOURCE: user manual
Hello HBurke!
Here's a copy of your owner's manual for your West Bend Coffee espresso maker, model #55129.
Please download a free copy and print it out for your use and future reference.
http://www.focuselectrics.com/supportdata/L5563G_55108-3in1_All.pdf
I've set up a file folder on my computer and labeled it "Home Appliances and Equipment" into which I save an electronic copy of all my manuals and guides, so I'll always have them available, just in case they aren't readily available on the internet in the future.
I hope you find this Very Helpful and best regards!
