Hi, I have put in a tape cassette in and its stuck. It doesnt seem to eject and doesnt seem to play the tape either. Ihave looked inside, it seems that one of the mechanism wheels is stuck, while the little wheels trying to, the other one doesn't which makes a very irritating clicking nose each time I turn it on. I cant seem to figure out what the problem is in the mechanism. and my tape is comopletely stuck! unless the head doesn't come off my tape has to stay in.
SOURCE: alpine head unit CDA-9855R
Yes, I'm sure Alpine will sell you another face but there is still the option of repairing the broken face at a good repair shop. Of course getting a new face is the easiest (read most expensive) way to get you going again.
SOURCE: stuck cassette in bose care stereo
I wonder if you were ever able to resolve your problem... I have a2000 ML 320 witht he same Bose issue... I get an error msg: TAPE TOO TIGHT... It won't even play and I get that same clicking sound when I try to eject... When I first purchased vehicle (used in 2002) I had the problem and the dealership assured me that they replaced the stereo with a new one...I never really tired it again until more than a year later and the same thing happened... Of course I was out of warranty at that time and I can't help, but to wonder if they really ever changed the stereo, or if they just removed the cassette.... If any has the solution, please contact me via email: [email protected]
SOURCE: jammed cassette tape in car stereo
your cassette seems to be jammed, try removing the player open it which should reveal the trapped cassette then try to carefully remove the tape as it may have got stuck around the capstans(rubber bits) sometimes when tapes haveen't been played for a long time they tend to become loose, try to ensure that the tape is tight by using a pencil inserted into the spool and turn it until the tape tightens please take care not to over tighten. good luk
SOURCE: I have a VW Polo (2005) with a Beta radio cassette
If you are not worried about breaking any thing I have always used needle nose pliers, when the tape is lifted pull it out with the pliers, don't put the tape back in.
SOURCE: face plate doesnt want to rotate all the way out
you may have a bad gear or gears inside the radio.
