SOURCE: After reinstall XP windows, it wont recognize my USB external hard drive anymore.
make sure that XP didnt turn off the USB in the BIOS... if you need assistants on reinabling it respond to this
SOURCE: I just inherited a Dell Latitude Laptop that
Yes ... Go to Start - Control Panel - System - Device Manager to see if there are any hardware conflicts or any other issues.
SOURCE: I have a Dell Inspiron 9200 running Windows XP
A remedy would be buying a card that goes into a slot on this pc that has usb ports- giving that a shot will help you other then that the motherboard would need to be replaced at this point the cheap way out would be to just by a card- Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Windows XP corrupted - Why can't I reload windows
You have to change the bios settings for making it boot from usb device. look at boot menu on the bios/usb cd-rom
SOURCE: how to enable internet on Dell Precision M4400
fistly confir that which antivirus u use.
if it norten, thn follow these step.
Scan for Internet-Enabled Programs and Apply Firewall Rules Using the Interface
Note:
All the programs that you select appear in the Program Control dialog box. In almost all cases, you do not need to modify the Internet Access or Category options. If you do need to modify these options, click the triangle to the left of the option in the Internet Access column and select the change.
If the application is still not working with your Internet connection, proceed to Check if a rule in Norton Internet Security or Norton Personal Firewall is Blocking Internet Access
