Its a very old set and if happens on all inputs and cables have been ruled out something serious--the rear inputs bypass the tuner in the set and based on its age I would not suggest spending major money (if you can find someone willing to work on a set of this age) on this set.
u need to reset the screen options back to regular spec if its not a 1080 p tv if its a regular tv you will need to use the 1080 p tv to fix it before you can use it on any tv
It could be the focusing, did you check the focus every time? A slow shutter speed also causes blurry pictures. I know you do use your tripod, but if you don't use the self-timer function or a shutter cable then you are not using the tripod properly. Also, check the front piece of glass in the lens, clean it if it has stains or whatever on it.
I'm guessing you have a delay set (people will use this on a tripod). The small button on the top left (next to the flash control) will solve your problem I think.
Do you have a led or crt display? It could be just your display settings. Go to control panel /display properties /setting tab / and try changing the screen resolution. If no difference try the color quality. You can change the color bits without hurting any thing. Just remember what you changed it from and to.
If this doesn't help maybe you'll need a new screen.
