SOURCE: pop up box appears periodically
try bringing up the menu, and see if there's an option "factory default", and try that. you didn't mention what button on the remote you press to get rid of the popup, or what feature you are turning off to get rid of the popup,
SOURCE: green interference on Panasonic TH-PX75U
Since the set is only 8 months old, it should still be under warranty. This may only be an internal connection problem, but opening up the unit will void the warranty. I would suggest that you call for warranty service. This is a problem with the set and has nothing to do with external devices or interference.
Keep us posted.
Dan
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
SOURCE: my panasonic viera plasma TH-42PX80U
Hi:
You will need to count the number of red led blinks on the power indicator, if it is at least 10 then replace the power supply it is faulty, In my years of servicing panasonic Plasma, power supply failure is about the most common failue in this class of television from this manufacture.
SOURCE: I plug in the USB
First, try using a different USB stick. If that doesn't fix the problem then your new tv is either faulty or the tv operating system has a bug.
Check the LG website in your country to see whether there are any firmware updates available. If not, then return the tv for refund or exchange, but make sure to try your USB drive on any replacement set in store as it's highly likely to be a bug in your model which will affect all of the other examples as well.
