Hi Teddy.
Regarding the issue you have with the memory card & the error message showing on the phone. It could be that the memory card you're using is not compatible with the phone model that you have.
Every phone has it's own maximum size of the memory card compatible to it.
E.x. A phone could only support up to 2Gb, but your memory card size is 4Gb.
You could contact your phone manufacturer & ask the maximum size of the memory card allowed for your phone.
If your memory card is compatible with your phone, you could just proceed in formatting the memory card on your phone.
**WARNING**
Formatting the memory card will erase everything saved in it.
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
