Question about Cisco ASA 5510 Firewall
Restart Cisco Asa 5510
I have a Cisco Asa 5510. I want to change the power supply from one connection to another. Can I just plug out the power connection and switch it. Will the Cisco Asa 5510 restart again. I just want to be sure before I do it.
    Problem Solver:
  • 8 Answers
Yes. The firewall will restart. Just be sure to save your running config to memory before turning off. For that you must issue the command: write memory.
Best Regards,
T
Posted on Apr 23, 2009
SOURCE:
How can i get into ASA 5510 after lost password
Its simple, you have reboot with console connect, get into to ROM mode and change configuration registry so it will not load the saved configuration. Please refer Resetting the passwords on Cisco ASA 5510 Binary Royale Ltd for the step by step process
Mar 21, 2013 | Cisco ASA 5510 Firewall
Time required, between moments I physically switch off and on again my Cisco ASA 5510, so the device starts correctly?
There isn't a set time. It is a good practice to turn it off long enough that the electricity can actually dissipate. It certainly won't hurt anything to leave it off for a minute before turning it back on. Even removing the power cord in between is ok.
Jul 06, 2017 | Cisco ASA 5510 Firewall
Block websites on cisco asa 5510.
All websites or specific ones?
If you want to block all web traffic, a straightforward rule preventing HTTP traffic (TCP port 80) as well as HTTPS (port 443) will block any and all web access.
If you just want to block specific sites, I'd recommend an access control list (ACL) configured to deny traffic to those specific site's IP addresses.
Feb 10, 2010 | Cisco ASA 5510 Firewall
New cisco asa 5510 setup
connect your laptop to the asa5510 using a cross over cable
Oct 07, 2009 | Cisco ASA 5510 Firewall
IPSEC problem between ASA and Microsoft ISA
can you try lower encryption levels on each device and see if that helps? sometimes it is neccesary between Cisco and other devices.
May 18, 2009 | Cisco ASA 5510 Firewall
The console port fails to connect suddenly
are you using hyper terminal? if you are using another program, switch to hyperterminal and reboot (if possible after saving config) with the cable connected. See if anything at all comes up on the screen.
Apr 16, 2009 | Cisco ASA 5510 Firewall
Installation of cisco asa 5510 firewall
Hello kuniksh,
Look at the below link for all configurations
http://www.akadia.com/services/cisco_router_firewall.html
Do rate this solution!!!!
Mar 21, 2009 | Cisco ASA 5510 Firewall
CIsco ASA 5510 fire wall problem
Hi Thangaraj_j,
Can you provide the topology of your setup? Can you provide also the following:
- running configuration of the ASA
- ip address of the server (what kind of server is this? what tcp/udp port does it use)
- show xlate
- show con
- show log
Just a quick try, have you tried clearing the translation and the arp table?
commands to do it:
clear xlate
clear arp
clear local
Let me know and if it still doesn't work, try to ping the server from the pc clients and see if ping does work. (you need to allow icmp to pass thru in case you are denying it for testing purposes) Just send me the additional information given above.
Regards,
ex_ocsic_cat
Nov 01, 2008 | Cisco ASA 5510 Anti-X Edition...
If you can't get the manament working initially I suggest the following
Setup a console connection
Type "enable" and press enter to access priveleged exec mode on the ASA
Type "config terminal" and press enter to access configuration mode
Type "configure factory-default" and press enter to load default settings.
Assign a static IP to your PC of 192.168.1.5 and try to browse to https://192.168.1.1 (PC is plugged into management interface)
You should be prompted to begin using ASDM
Jul 30, 2007 | Cisco ASA 5510 Firewall
Cisco ASA 5510 Firewall Logo
4,269 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
